Honda Fit Honda Fit (Jazz)
Crazy thought on factory alarm + aftermarket..
Old Jun 27, 2007 | 11:07 AM
tgreaves's Avatar
Default Crazy thought on factory alarm + aftermarket..
As any Fit owner knows the factory alarm system is part of the keyfob..
I want to add an aftermarket alarm w/ remote start to my Fit..
Has anyone thought of doing something where the factory keyfob will activate the aftermarket alarm? Something like dismantleing the aftermarket alarm fob and using the factory arm/disarm output to provide arm/disarm directly to the aftermarket fob and mount the aftermarket keyfob under the dash.. Something like using a small fast acting relay instead of the button on the aftermarket fob so that when you press the arm button on your factory keyfob it will "press" the arm button on the aftermarket fob thats under the dash..
What about moving the key and transponder into another case that doesnt have the arm/disarm on it and using the aftermarket alarm fob?
It would be too easy but has anyone seen an aftermarket alarm that have an arm/disarm wires on it?
Old Jul 3, 2007 | 07:02 PM
Payneful13's Avatar
http://www.viper.com/Products/...D=111
Check that web addy. That's Vipers OEM alarm, uses factory key fob's. It doesn't have remote start built in, but I'm sure you can find an add-on module to start it up.
ipleadthe5th
Audio / Security / Video
16
Apr 21, 2017 06:49 PM
jmacsss
Jun 15, 2012 02:05 AM
GoLowDrew
May 30, 2006 03:37 PM
Black R
Sep 16, 2004 03:10 PM
