LS ALL MOTOR
Old Jun 27, 2007 | 10:41 AM
ls_all_motor#97's Avatar
Default LS ALL MOTOR
Now I understand that people don't think you could pull out 210whp out of an ls motor. But if you were to bore it over or swap out the bottom end for a B20 how much horsepower do you think I could pull? By the way I know I could bore it to a 2.2 but how safe would it be without sleeves?
Old Jun 27, 2007 | 10:46 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: LS ALL MOTOR (ls_all_motor#97)
If you bore a b20's stock sleves you are asking for trouble. 210 all motor hp is pretty hard to reach with an LS motor. I'm sure it can be done but its going to cost alot of money.
Old Jun 27, 2007 | 11:13 AM
AWD Terror's Avatar
It can be done, but the entire motor will need re-done. I would deff get the block built & sleeved to reach these goals.
Old Jun 27, 2007 | 11:19 AM
Default Re: (AWD Terror)
Well thank you for the insite. I have been toying with turbo or all motor and I watched a couple of video's last night on my computer and well they inspired me to just stay with all motor. But thanks, also do you think I should just stick it out with the 1.8 but bore it to a 2.0 or I could stroke it.
Old Jun 27, 2007 | 11:25 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (ls_all_motor#97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_all_motor#97 &raquo;</TD></TR><TR><TD CLASS="quote">Well thank you for the insite. I have been toying with turbo or all motor and I watched a couple of video's last night on my computer and well they inspired me to just stay with all motor. But thanks, also do you think I should just stick it out with the 1.8 but bore it to a 2.0 or I could stroke it.</TD></TR></TABLE>
Your probably going to need to do both, along with high compression pistons, crazy race cams, a hell of a tune, etc... then about $5k later you will probably reach your goal and have a 210whp 13 second car that is going to be a bitch to drive on the streets.... or you could rebuild the motor you have now boost it and have a 350whp low 12 second car for cheaper, it will be a good daily driver and be just as reliable as the all motor setup...
Old Jun 27, 2007 | 11:43 AM
DB1_559's Avatar
go allmotor i wanna see a ls/b20 pull 210whp im thinking of doing the same with a stroker kit but i rather supercharge it really
Old Jun 27, 2007 | 11:44 AM
unknown0001's Avatar
Default Re: LS ALL MOTOR (DB1_559)
check out this build
https://honda-tech.com/zerothread?id=1765855
Old Jun 27, 2007 | 11:51 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: LS ALL MOTOR (Mr.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.R &raquo;</TD></TR><TR><TD CLASS="quote">check out this build
https://honda-tech.com/zerothread?id=1765855</TD></TR></TABLE>
thats one nice build
96Integraracer
Oct 29, 2007 12:21 PM
jpb105079
Jul 7, 2004 11:21 AM
VtecDA9
16
Jan 15, 2004 06:26 PM
