solid cel and fuel pump doesnt prime
my car was starting fine for a while and i was trying to figure out a vacume leak. but last time i went to go start it i got a solid cel the ecu never flashes to show it gets power and the fuel pump doesnt prime
i thought it was just a main relay so i swaped it with 3 diffrant known working ones and its still the same issue.
i also tested my ignition switch in another car and it works fine
im sort of running out of ideas besides maybe some bad wiring in the dash but i havent touched it recently so i dont know what it could be.
i do know if i hit the main relay the cel turns off and the ecu will flash for a sec but i guess that is just like the switch in it making contact for a second.
does any one have wiring diagrams for the the main relay and where all the power goes to and comes from??
i have tried
2 working pm6 ecus
1 working pr3
1 working pr4
and a p28 with a jumper harness
all of these ecus will get my buddys crx to idle but not mine
2 working pm6 ecus
1 working pr3
1 working pr4
just for ***** and giggles were picking up another pm6 today its chipped im 100% sure it wont help but ill try it any way
any one else have any ideas before i start fishing through all the wiring tomorrow?
bump any one got a suggestiong??
im on my way to where i store the car in a little bit to work on it im probly just going to trace all the wiring unless some one comes up with another suggestion
ok i took the main power coming in to the relay and jumped it to the ecu pin and the fuel pump pin and it starts fine
well sort of i get a iavc code but it idles just low and dies when it gets gas but i guess this sort of fixs well patches my problem for now
From: I told you to wait in the truck in Texas, United States
all grounds are good i tested each of them and re did the ground on the main relay still no luck
i figgure if i can fix the idle issue and just leave the jumper ill just use it like a cut off switch to make it a little harder to steal the car
plus im to lazy to dig through all these wires
Do you have the manual ( helms ) you need to pick one up if not. They will have step by step procedures on what to do for these types of problems. It sounds like you have some issues that no one will really be able to help, so your going to have to break out a multi meter and a helms and go to town
the setup is a b16a in a crx si with a tucked harness
looking at it being something in the tucked harness being the issue
and bob ive been going through with the multi metter for a couple days just hate crawling around and found this to be an easy half *** fixed
blackeg
Apr 3, 2007 07:07 AM
turbocivic96
Mar 15, 2004 12:35 PM
