Need extended lugs for oem wheels
Old Jun 27, 2007 | 09:33 AM
ITR32's Avatar
Default Need extended lugs for oem wheels
Who makes extended lugs for oem ITR wheels. Seems like most of them are only for aftermarket.
Old Jun 27, 2007 | 10:10 AM
toyomatt84's Avatar
Sanji
Lug nuts or just lugs?
Old Jun 27, 2007 | 10:41 AM
ITR32's Avatar
Default Re: (toyomatt84)
Lug nuts
Old Jun 27, 2007 | 10:44 AM
CB7.v2's Avatar
probably not possible because most aftermarket extended lug nuts have a tapered tip which normally won't fit on oem honda wheels as they have domed lug nut seats.
Old Jun 27, 2007 | 10:59 AM
ITR32's Avatar
Default Re: (CB7.v2)
So pretty much stick with honda lugs
Old Jun 27, 2007 | 11:29 AM
RPRacing's Avatar
you mean something like this? http://passwordjdm.com/Buddy-C....aspx
if so, pm me and I'll give you a price.
Old Jun 27, 2007 | 01:06 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CB7.v2 &raquo;</TD></TR><TR><TD CLASS="quote">probably not possible because most aftermarket extended lug nuts have a tapered tip which normally won't fit on oem honda wheels as they have domed lug nut seats.</TD></TR></TABLE>
WRONG. The logic behind your reasoning is correct, but they are indeed available.
Obviously, you didn't bother looking at other recent topics of discussion. Like this one, which tells where you can get open-ended lug nuts with the ball-shaped seating area for OEM Honda/Acura wheels.
Old Jun 28, 2007 | 06:53 AM
fventura03's Avatar
walmart sells oem lugnuts that are open ended 12x1.5mm
Old Jun 28, 2007 | 07:55 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">walmart sells oem lugnuts that are open ended 12x1.5mm</TD></TR></TABLE>
Do they have the ball-shaped seating area?
Old Jun 28, 2007 | 08:42 AM
fventura03's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
i think so, says oem spec.
Cap'N Chronic
Jan 22, 2013 09:42 PM
Shoey
Sep 21, 2012 02:42 AM
boosted.CRX
Jul 13, 2006 12:45 PM
fms1day
May 24, 2006 09:41 AM
99_dc2
Feb 21, 2006 01:05 PM
