d16y obd2 sohc dual vtec enige?????
Old Jun 27, 2007 | 07:57 AM
b20vtecturbe's Avatar
Default d16y obd2 sohc dual vtec enige?????
does anyone know the purpose or how this d16y sohc dual vtec engine works with dual vtec and its a single cam motor i seen it on ebay, just wondering?????
Old Jun 27, 2007 | 09:12 AM
99 Civic EX's Avatar
Default Re: d16y obd2 sohc dual vtec enige????? (b20vtecturbe)
sohc vtec only has vtec lobes for the intake, there is no dual vtec sohc.
Old Jun 27, 2007 | 09:53 AM
Default Re: d16y obd2 sohc dual vtec enige????? (99 Civic EX)
click this ebay posting and i have also seen this motor on 3 other websites check it out for yourself i mean i know as much as you told me but i came accross this and was wondering how in the hell that works, lol.......
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jun 27, 2007 | 09:57 AM
TypeRobert's Avatar
hmm that picture looks like a d16y5 e-vtec
Old Jun 27, 2007 | 10:18 AM
Default Re: d16y obd2 sohc dual vtec enige????? (TypeRobert)
yeah it is a d16y5 i found out its from the 99-2000 hx model civic its simular to the vx model eg, thakns for all your help guys
Old Jun 27, 2007 | 10:21 AM
motor_man's Avatar
it says its a d15 not 16?
Old Jun 27, 2007 | 10:58 AM
Budget Racer's Avatar
Default Re: d16y obd2 sohc dual vtec enige????? (motor_man)
Did you message the seller?
Check out the vtec selonoid in tha pic though it appears there is two in one!!
Strange dunno so bump
Old Jun 27, 2007 | 01:46 PM
Default Re: d16y obd2 sohc dual vtec enige????? (Budget Racer)
yeah i messaged them waiting for response just wanting to know what the purpose of 2 selonoids are for as if theres a dual vtec kick in threw each gear just intresting to find out never seen before, i just know its from the economy hx civic so it cant be anything to wild
Old Jun 27, 2007 | 01:48 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecturbe &raquo;</TD></TR><TR><TD CLASS="quote">yeah i messaged them waiting for response just wanting to know what the purpose of 2 selonoids are for as if theres a dual vtec kick in threw each gear just intresting to find out never seen before, i just know its from the economy hx civic so it cant be anything to wild</TD></TR></TABLE>
Its the JDM D15b with 3-stage, it has both VTEC-E, and the Normal VTEC. Search it up, im not going to write it all out (again)
Old Jun 27, 2007 | 02:11 PM
sageuvagony's Avatar
Default Re: d16y obd2 sohc dual vtec enige????? (97Ej6mike)
3-stage VTEC
Examine the SOHC VTEC and SOHC VTEC-E implementations. The clever Honda engineers saw that it is a logical step to merge the two implementations into one. This is in essence the 3-stage VTEC implementation. 3-stage VTEC is implemented on the D15B 1.5l SOHC engine in which the VTEC-E mechanism is combined with the power VTEC mechanism.
Many of us probably has laughed at the poor ignorant layman who said "I want power AND economy from my Honda". We know of course that power and economy are mutually exclusive implementations. Honda decided not to abide by this rule. Now, with 3-stage VTEC, we get BOTH power and economy !.
The diagram below illustrates the 3-stage VTEC implementation. The intake rocker arms have two VTEC pin actuation mechanisms. The VTEC-E actuation assembly is located above the camshaft while the VTEC (power) actuation assembly is the standard wild-cam lobe and rocker assembly.
Below 2500rpm and with gentle accelerator pressure, neither pin gets actuated. The engine operates in 12V mode with very good fuel combustion efficiency. When the right foot gets more urgent and/or above 2500rpm, the upper pin gets actuated. This is the VTEC-E mechanism at work and the engine effectively enters into the '2nd stage'. Now D15B 3-stage works in 16V mode (both intake valves works from the same mild cam-lobe).
Stage 2 operates from around 2500rpm to 6000rpm. When the rpm exceeds 6000rpm, the VTEC mechanism activates the wild cam-lobe pushing the engine into the '3rd stage', the power stage. Now the engine gives us the full benefit of its 130ps potential !
The 3-stage VTEC D15B engine is used on the current EK-series JDM Civic/Civic Ferio VTi/Vi together with Honda's new Multimatic CVT transmission. Stage-1 12V or "lean-burn" operation mode is indicated to the driver by an LED on the dashboard. The 2500rpm cutover from lean-burn to normal 16V operation in fact varies according to load and driver requirements. With gentle driving, lean-burn can operate up to 3000rpm or higher. Stage-3 may not always be activated. The Multimatic transmission has a selector for Economy, Drive, and Sports mode. In Economy mode for eg, the ECU operates with a max rpm of around 4800rpm even at Wide-Open-Throttle positions.
The essence of 3-stage VTEC is power AND economy implemented on a 1.5l SOHC PGM-Fi engine. Many people mistakes 3-stage VTEC as a "superior" evolution of the power oriented DOHC VTEC implementation, describing DOHC VTEC as "the older 2-stage VTEC" and implying an inferior relationship. This is totally wrong because DOHC VTEC is tuned purely for high specific output and sports/racing requirements. 3-stage VTEC is in truth an evolution of SOHC VTEC and VTEC-E, merging the two implementations into one.
got this from another post.
Old Jun 27, 2007 | 04:22 PM
Default Re: d16y obd2 sohc dual vtec enige????? (sageuvagony)
thanks that explains everything now
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Its the JDM D15b with 3-stage, it has both VTEC-E, and the Normal VTEC. Search it up, im not going to write it all out (again)</TD></TR></TABLE>
Yup.
Duramax66
Jul 11, 2012 08:28 PM
db1_jdm
Dec 17, 2007 10:10 PM
Ignitecivic
23
Aug 27, 2004 07:41 PM
92hatchattack
May 7, 2004 02:31 PM
crzyfool24
Nov 17, 2003 02:32 PM
