LS - - - - > GSR in 92cx
Old Jun 27, 2007 | 06:49 AM
ThinkRevolution's Avatar
Default LS - - - - > GSR in 92cx
Quick question - if I have an LS swap (B series) in my civic, can I just change the long block / ecu(?) over to GSR since the linkage / axles etc are all already B series?
Old Jun 27, 2007 | 08:24 AM
Gkdc182's Avatar
Default Re: LS - - - - > GSR in 92cx (ThinkRevolution)
yeah you can but you will have to run some wires for vtech....and you will have to run the vtech head!!!! Everything else should bolt right up............
Old Jun 27, 2007 | 09:26 AM
Default Re: LS - - - - > GSR in 92cx (Gkdc182)
vtech head would come with the GSR longblock no?
and it DOES require an ECU change of course correct?
Old Jun 27, 2007 | 09:39 AM
redhatch8u-up's Avatar
in order for VTEC to work correctly then yes adding some additional wiring and a p72 computer to run the gsr motor would be necessary.
Old Jun 27, 2007 | 12:23 PM
Default Re: LS - - - - > GSR in 92cx (redhatch8u-up)
ok so just to sum up.
In order to switch from LS - - > GSR in my CX
All I would need is to wire up vtec and get a p72 computer.
Correct?
Old Jun 27, 2007 | 01:39 PM
Boostedb20EH2's Avatar
My cx already had wires for vtec..?
Old Jun 27, 2007 | 02:05 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThinkRevolution &raquo;</TD></TR><TR><TD CLASS="quote">vtech head would come with the GSR longblock no?
and it DOES require an ECU change of course correct?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gkdc182 &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can but you will have to run some wires for vtech....and you will have to run the vtech head!!!! Everything else should bolt right up............</TD></TR></TABLE>
OMG TEH VTECH!
No H in Vtec, lol.
Modified by 97Ej6mike at 4:38 PM 6/27/2007
Old Jun 27, 2007 | 02:49 PM
amish_assassin88's Avatar
ya, pretty sure the cx is already wired up for vtec
Old Jun 27, 2007 | 03:16 PM
1d10t's Avatar
Default Re: LS - - - - > GSR in 92cx (amish_assassin88)
my 92 CX is vtec ready.
Old Jun 27, 2007 | 03:36 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amish_assassin88 &raquo;</TD></TR><TR><TD CLASS="quote">ya, pretty sure the cx is already wired up for vtec </TD></TR></TABLE>
a civic CX does not have VTEC in its harness. the 92-95 CX's have the D15b8, SOHC NonVTEC
Only civic's that come with VTEC in thier harness are the Civic EX, SI, and the HX/VX models.
Old Jun 27, 2007 | 04:20 PM
Default Re: LS - - - - > GSR in 92cx (97Ej6mike)
Im no honda encyclopedia..
But considering mine and 3 other people had wires for it in their harness.. It is in the harness.
bitzbp
Jun 9, 2012 05:34 PM
airikkCRX
Jun 8, 2007 12:46 PM
1INTEGRA
Dec 26, 2005 10:20 AM
youngwon22
Oct 27, 2003 04:12 PM
