electrical load detector HELP!
Old Jun 26, 2007 | 11:43 PM
minime-civic's Avatar
* B A N N E D *
Default electrical load detector HELP!
okay so ive never heard of this thing before and also, im also flashing 2 long blinks and 1 short, if u guys could help me out that would b great, another thing, my car wil start, but it wont idle, so i messed with the throttle cable, and that doesnt help, and i also played with the little screw on the throttle body, help me! please!
Old Jun 27, 2007 | 12:35 AM
slowcivic2k's Avatar
Default Re: electrical load detector HELP! (minime-civic)
This may be helpful, but an odd way to diagnose this problem, I had a similar problem when my second O2 sensor connector shorted to ground because I no longer have a need for it, it would blow the alt/sp sensor fuse, and threw that code. The only way I can see that thing going bad is if you hammer the **** out of the fusebox. It's the little brown thing inside the fusebox that has a metal plate going through it. If you tampered with any of your wiring, check all of it, it took me 3 days to figure mine out, because I forgot all about that second O2 harness.
Old Jun 27, 2007 | 01:06 AM
* B A N N E D *
Default Re: electrical load detector HELP! (slowcivic2k)
well it only flashes that code when my p28 is in there. when i put in th p06 theres no cels,
hickle
12
Feb 8, 2010 07:24 AM
benjamin80
Honda Civic (2001 - 2005)
Sep 23, 2008 10:22 AM
Panda0000
Aug 17, 2007 09:12 PM
eflove
Dec 8, 2005 01:11 PM
turbotime
18
Jul 16, 2003 03:28 PM
