seat sliders/brackets
what kind of sliders and brackets should i use in my 89 crx with buddy club seats. i would like to retain the low seat position if at all possible. will sparco sliders work? any other suggestions would be great.
I've used the stock slider and fabbed up some 2" x 1/4" thick alumnium flat bar to adapt the seat hole spacing to the stock slider. With the appropriate bolts and washer combination my Momo seat sits lower that stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solorex »</TD></TR><TR><TD CLASS="quote">I've used the stock slider and fabbed up some 2" x 1/4" thick alumnium flat bar to adapt the seat hole spacing to the stock slider. With the appropriate bolts and washer combination my Momo seat sits lower that stock.</TD></TR></TABLE>
how did you do this?
is there any other combo i could use?
if u dont have door mounted seats belts. otherwise u cant use these.
the lowest available.
memoryfab, nagisa, make some
http://cgi.ebay.com/NAGISA-NAM...wItem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">if u dont have door mounted seats belts. otherwise u cant use these.
will those seat rails you posted work with the buddy club seats?
someody help me out here then. how can i have low seat position with 89 si doors? which brackets would work? or what do i need to do to make a set of brackets work.
EDIT: also, why won't they work?
Modified by 95lscivic at 7:04 PM 6/27/2007
prostreetonline
19
Apr 19, 2005 01:09 PM
REFLUX
Apr 22, 2003 02:04 PM
