temp gauge problem
Check the underdash fuse box for a blown fuse. I dont know exactly what circuit the temp sensor is on, but check all the fuses. Or look at the bottom of the fuse cover.
The temperture sensor is located right outside of the thermostat. Follow your lower radiator hose until it connects to a metal housing which holds your thermostat and the sensor should be sticking out of that.
that sensor is actually the coolant fan switch sensor...
the temp sensor is the little sensor on the head closest to the radiator...
might just be the temp gauge that is busted...try a friends cluster out...
