I need Help removing and replacing exterior door handle...
this is my first question on honda-tech...but i need help and was wondering if anybody knew how to remove and replace the exterior door handle...? I broke it a couple of months back and i jsut bought a new one...anything would help please....
remove the door panel, be careful to make sure the your get all the screws out of the door panel. make sure the window is rolled up, theres 10mm nuts or bolts that secure the handle from the inside. also be careful removing the clips that hold the rod form the inside. those you have to remove b4 you can take the handle out. good luck.
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
babyviper97
Jan 10, 2003 05:14 AM
