ID these rims, please
the seller does not know what the brand is so i cant figure out the offset.... this is what he says is stamped on the rim: tectran d249 and 17X7 1/2jj what are these rims ..?
what car had these previously or why not test one (local)? if you understand the definition of offset, you could actually calculate it yourself by measuring the wheel. for a 7.5" wide rim, you will need an offset in the mid to high 40s for it not to rub if lowered (esp with the 235 rubber).
JDMPIRE_69
Feb 8, 2013 09:11 PM
