GSR valve adjustment
Old Jun 26, 2007 | 05:49 PM
old_school_dohcvtec's Avatar
Default GSR valve adjustment
I will be doing a valve adjustment on my GSR later this week and I plan to follow the c-speed article. The article mentions that a modified wrench can be used to do the job. For all the people that used a modified wrench, did you guys heat up the wrench and then bent it? or did you simply just bend the wrench into shape.....
thanks
Old Jun 26, 2007 | 06:28 PM
Bignel00's Avatar
Default Re: GSR valve adjustment (old_school_dohcvtec)
honeslty it doesnt matter you can do it either way , heat up or bend , it still works the same
Old Jun 26, 2007 | 08:19 PM
doood's Avatar
been there done that
you must be one strong sonofabitch to bend a wrench without heating it up
Old Jun 30, 2007 | 12:07 PM
Bignel00's Avatar
Default Re: GSR valve adjustment (doood)
yessir
Old Jun 30, 2007 | 12:46 PM
Liquidgsr's Avatar
Default Re: GSR valve adjustment (Bignel00)
isn't there a tool on amazon for valve adjustments so you don't need to do this?
Old Jun 30, 2007 | 12:52 PM
Padawan's Avatar
Darth ModerVader
Default Re: GSR valve adjustment (Liquidgsr)
There is a special tool for the job, but the adjustment can be performed using just a regular wrench, a screwdriver, and a feeler gauge.
Old Jun 30, 2007 | 06:57 PM
THE LORD OF CHAOS's Avatar
i bought the jam nut tool from amazon for my valve adjustment. it was cheap and made the job much easier. i would recommend doing that.
gsr96cx
Aug 25, 2008 06:11 AM
Gomdohree
Jun 2, 2008 05:53 PM
Powered by VTEC
16
Jan 20, 2008 03:47 PM
00preludeh22a
Feb 21, 2007 04:43 AM
SamC
Jan 24, 2003 08:52 AM
