ATE vs Motul 600
Time to bleed again...I don't really mind using some extra oils to make sure oils are all bleed out. So ATE blue or not is not too important. I want performance and reliability first! I think Motul had a longer history and better known performance than ATE...right? And what about their spec, anyone know the boiling points...etc? Some said in the past that ATE comes with metal containers and Motul with plastics, saying that Motul is easeir to trap mositure if kept for long...is this true?
Finally, where can I buy boxes of ATE or Motul online for cheap?
try the motul site http://www.motul.com they have the specs of the Motul RBF600 brake fluid.
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
No prob, Ray.
BTW, it was a pleasure to meet you and David and Oscar and Edwin and Lance and Ralph and the rest of the NE crew at the Expo!
[Modified by nsxtcjr, 11:37 PM 6/6/2002]
dutchman5
Mar 25, 2003 03:26 AM
ActiveAero
Mar 23, 2002 08:44 PM
Motul it is for eternity!
