any new york people in here??
Old Jun 26, 2007 | 04:57 PM
JJ's civic's Avatar
Default any new york people in here??
just bought a si hatch but the rear lift supports are gone( the metdal you use to lift the rear up with) is gone. will it still pass inspetion even with them rusted gone or weak??
Old Jun 26, 2007 | 05:09 PM
Crx Jimmy's Avatar
Default Re: any new york people in here?? (JJ's civic)
sure it will, they didnt open my hatch during the inspection, just the hood to look for leaks/broken stuff
Old Jun 26, 2007 | 05:10 PM
JJ's civic's Avatar
Default Re: any new york people in here?? (Crx Jimmy)
how did they lift it i mean the support you use to lift the car is gone on one side and weak enough i can move it with my hands. where in ny vt you from??? i'm near plattsburgh
Old Jun 26, 2007 | 05:48 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">any new york people in here??</TD></TR></TABLE>
Member Search
State: ny
List Order » Users will be returned in the following order.
8416 users found
shitload of newyorkers!
Old Jun 27, 2007 | 01:57 AM
JJ's civic's Avatar
Default Re: any new york people in here?? (STREETWERKZ)
did you read the post though i had a question about inspection.
Old Jun 27, 2007 | 05:20 AM
CRX Toad's Avatar
Are you talking about the rear hatch lift supports or the jack points that are below the car that you put on the lift?
Old Jun 27, 2007 | 06:08 AM
DenzComp's Avatar
I'm very confused.
Either way...there are no shops that are "lick and stick"?
I've had SEVERAL cars pass inspection at shops that only check lights, horns, and wipers. Not even put on a lift.
Ask around, there's gotta be one somewhere near.
Old Jun 27, 2007 | 09:35 AM
91ed9's Avatar
Default Re: (DenzComp)
it might be different where im from (NYC) queens bc its different from long island insp to NYC to upstate ny there all different
but just find a shop that DOES NOT lift the car up bc if im reading corectly you cant lift it up
but if you cant lift you will fail inspection bc they cant check what there suppost to
but if you find a place that only looks under the hood and puts the car on the DYNO then you should be fine unless it wont pass emissions!
Old Jun 28, 2007 | 02:07 AM
JJ's civic's Avatar
Default Re: (91ed9)
they dont' lift your car down in long island?
i'll have to drive my truck down there then lol. no really everyone up hee lift them up. and i'm talking abou the support to lift the whole car up.
Old Jul 3, 2007 | 05:49 PM
JJ's civic's Avatar
Default Re: (JJ's civic)
bump
Old Jul 4, 2007 | 07:12 AM
91ed9's Avatar
yea some people do down here, just find someone that will pass you just slip them an extra 30 bucks and youll see how far it will get you
if not then you have to find someone wiht a drive on lift!
Old Jul 4, 2007 | 08:50 AM
Crx Jimmy's Avatar
Default Re: (91ed9)
just go to one of those quick lube places, they just look from the bottom from their hole they work in. they usually dont jack it up. Also go when its raining out, they really dont like to get wet and the water can hide any leaks underneath you have because everything looks wet
Old Jul 4, 2007 | 09:12 AM
JJ's civic's Avatar
Default Re: (Crx Jimmy)
jiffy lube can do a inpection?
Old Jul 4, 2007 | 10:46 AM
cb07's Avatar
Yep. At least we do in NM....
Old Jul 7, 2007 | 08:24 AM
91ed9's Avatar
They dont here on LI
f22 lx
Aug 7, 2006 07:52 AM
EL Vap133
Mar 30, 2006 03:43 PM
Khmi
Mar 20, 2006 08:14 PM
JdMCiviCCupE
Dec 7, 2003 12:16 PM
Big Teggie
Jul 7, 2003 10:33 AM
