Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Major brake and control arm assembly question
Old Jun 26, 2007 | 04:36 PM
ShadowLead's Avatar
Default Major brake and control arm assembly question
I own a Honda Civic 2001 EX (unmodified)
Recently I went to go remove the front left tire of the car and in the process of removing the nuts, I ended up sheering 3 out of 4 bolts off with the nuts still attached.
I removed the tire and found the previous servicer (Big O Tires) made the mistake of crossthreading the bolts.
Thats besides the point now.
In an attempt to replace the bolts I ran into a problem with removing the plate the bolts have to run through to attach to the tires.
After discussion with a mechanic he suggested that I might have to have the bearing pressed out of the assembly.
This wouldnt be a problem except for the fact that I cant remove the assembly because of the bolt on the lower part of the assembly attached to a ball and socket connection to the plate and brake assembly cant be removed by any amount of force.
I really need help and advice to remove this piece of the assembly.
Old Jun 26, 2007 | 05:18 PM
toyomatt84's Avatar
Sanji
You'll need a Ball joint / Tie rod end puller.
Old Jun 28, 2007 | 01:09 PM
k20whitevic's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">You'll need a Ball joint / Tie rod end puller.</TD></TR></TABLE>
^^ I'm with him!
Old Jun 28, 2007 | 02:14 PM
toyomatt84's Avatar
Sanji
Default Re: (k20whitevic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20whitevic &raquo;</TD></TR><TR><TD CLASS="quote">
^^ I'm with him! </TD></TR></TABLE>
Long time, no see, Shawn. How have you been?
TypeRMOBBiN209
Sep 24, 2009 03:11 PM
superman3503
Suspension & Brakes
May 25, 2006 08:15 PM
Dseriespower
10
Dec 7, 2003 08:09 PM
SL!M
Jun 2, 2003 06:20 PM
