how do you take off the valve cover??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">It's a very straightforward task. Just start removing **** man.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">unscrew the nuts that hold it on.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I heart my Honda. »</TD></TR><TR><TD CLASS="quote">Just remember when you put it back on to not over torque the bolts. You don't want to snap them off in your head.
hey you should explain to op how to put it back on properly lol .... im such a hole
but yeah man dont forget to get a new gasket when u put it back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastLife617 »</TD></TR><TR><TD CLASS="quote">
you really only need a new one if your old one is leaking. Just clean it good and then reapply liquid gasket on the square sections of the gasket (around the cams). Then make sure you don't over tighten the cover nuts cause they can break and turn into crap. Usually 10 foot lbs is good
</TD></TR></TABLE>you really only need a new one if your old one is leaking. Just clean it good and then reapply liquid gasket on the square sections of the gasket (around the cams). Then make sure you don't over tighten the cover nuts cause they can break and turn into crap. Usually 10 foot lbs is good
oh booooo everyonwe starts somewhere. here ya go dude:
<U>remove</U>
label and unplug spark wires (from head not distributor)
unscrew the nuts
it should pull right up afer that
<U>install</U>
clean off the edges
replace spark wires as labled
tighten nuts
<U>remove</U>
unscrew the nuts
<U>install</U>
clean off the edges
tighten nuts
