Integra stuttering after warming up
Old Jun 26, 2007 | 03:11 PM
n00bfasho's Avatar
Default Integra stuttering after warming up
When I start up my car in the morning, it drives nice and smooth until the engine has warmed up. Then, when I press on the gas at lower rpms, the car stutters and struggles. During hot days especially, the car really has trouble. Can you guys give me suggestions as what the problem could be? Thanks.
Old Jun 26, 2007 | 03:12 PM
g0tgot's Avatar
tune up/// dunno try cleaning the air filter?
Old Jun 26, 2007 | 03:38 PM
Agent_EM1's Avatar
Default Re: Integra stuttering after warming up (n00bfasho)
Are you using 10w30 instead of 5w30? Happened to me before...
Old Jun 26, 2007 | 03:45 PM
n00bfasho's Avatar
I have I/H/E. Are you saying to clean the air filter on the intake? Yeah I am running 10w30 right now. Next oil change I will switch to 5w30. However, the guy I bought it from said that 10w40 was better than 10w30 for the car. It has a type R head on gsr block if that explains anything. Thanks for the input so far.
Old Jun 27, 2007 | 03:14 PM
n00bfasho's Avatar
bump for help
Old Jun 27, 2007 | 03:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
dang that sucks, ITR head on GS-R block yields only 9.8:1 CR vs. stock GS-R of 10.0:1
Old Jun 27, 2007 | 11:35 PM
Sumslapper's Avatar
Year 3030
Default Re: (PatrickGSR94)
10w40 is not necessay. sounds like it could be a distributor or something to do with ignition/timing. does the tach ever randomely bounce around or does the car ever cut out/misfire? i would do a tune up with plugs/wires cap, rotor, oil change, fuel filter and go from there
Old Jun 28, 2007 | 03:59 PM
n00bfasho's Avatar
The tach idles pretty consistently. Thanks for the other advice Sumslapper.
92gsrtegger
Sep 2, 2014 06:47 PM
reithegreat
Jun 28, 2009 09:52 PM
Teglessb18
Aug 24, 2005 03:48 PM
SymphonyX
15
Feb 28, 2003 10:10 PM
Zulu888
Aug 23, 2002 06:09 AM
