mounting engine hoist chains to motor/tranny
this is where one chain hoist goes correct? with any length 10 mm bolt?
where should i mount the chain for the tranny side? the circle part is where I think it should go but not to sure.
I always use tie downs just cause I can make quick adjustments and usualy wrap the tie down around that mount...but if you have a chain ya use that hole but might have to get a longer bolt to fit the chain through.
looking at the first pic thats the hole i always use and the one on the other side of it, then for the trans side i use one of the bolts on the trans housing that bolt to the motor.
Modified by DaNnYsEvEn at 6:19 PM 6/26/2007
I just use the top side starter bolt and then on the motor I attach the chain to the hole where the P.S. bracket normally bolts to, that way the motor is supported by 14mm bolts the whole time so there is no worry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">Who uses a cherry picker on a Honda? get some very large jack stands and drop it out the bottom
I used to think the same until I actually had to do the swap in my driveway and not in a shop w/ a lift. The cherry picker gave me alot more control when lowering and raising the motor. Just using a jack and big jack stands was a little more skidish when taking the original motor out and I knew it would be harder to get the motor back in w/o flexing the front end alot and likely would scratch the bay up a good bit which I was not about to do.
I am all about using a lift and dropping the motor from the bottom but w/o a lift? the cherry picker is sooooooo damn handy.
Bottom line is to use at least a 12mm bolt or bigger when hoisting the motor and just try to attach the chain so the motor will balance out when hanging freely. just use some common sense and you'll be fine
</TD></TR></TABLE>I used to think the same until I actually had to do the swap in my driveway and not in a shop w/ a lift. The cherry picker gave me alot more control when lowering and raising the motor. Just using a jack and big jack stands was a little more skidish when taking the original motor out and I knew it would be harder to get the motor back in w/o flexing the front end alot and likely would scratch the bay up a good bit which I was not about to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si »</TD></TR><TR><TD CLASS="quote">hmmm tie downs seem like a good idea...</TD></TR></TABLE>
That's what we did for my first swap.
Bolted a wench to the ceiling and stood a board from the floor to the rafters so the shitty garage wouldn't topple.
mingchi69
Sep 8, 2003 10:58 PM
