will my cars pass smog
I plan on moving to the bay area within the next 9 months or so but I don't know if my cars will pass smog. I was reading a thread on here about a b16 so I thought I would start my own thread.
The first car is a '91 STD with a Y8 mini-me swap, p28 ECU, intake, header, exhaust and that's it.
The second car is a '88 STD converted to multi-point with intake, header, and exhaust.
They both have cat converters if that helps. Thanks guys
Agreed on the first one for sure!
The other one should pass as long as the intake is CARB approved.
Actually the second one sounds almost exactly like my car. As long as the Cat is fairly new and its nice and hot, you should have no problem passing smog. Mine has an intake and exhaust, no header, but it passed with flying colors, well right after i put the new cat in.
Good luck!
Good luck!
