91 ef hatch SHIFT FORK/LEVER HELP!!! have ne clue...any ideas?
Old Jun 26, 2007 | 10:13 AM
94eg5squadMD's Avatar
Default 91 ef hatch SHIFT FORK/LEVER HELP!!! have ne clue...any ideas?
i have 91 ef hatch with d16z6 in it...
the car was running fine untill started to have a 3rd gear grind...so i droped the trans
i bought another 91 si trans and bought a competion six puck clutch for a d16z6...
once i put the clutch on and bolted the trans up....my clutch fork has 100% play...i can lift it all the way up to the top...its not hard at all it has complete play.....so once i connect my clutch cable and try to drive the car the clutch pedal goes to the floor and it dont disengage my clutch so i cant get into gear?
what do i do???
d16z6 with a 91 si trans....competetion stage 4 6 puck clutch...help??????
throwout bearing?
if i buy a new throwout bearing what do i order it for 1991 honda civic si transmission?
where can i get one?
Old Jun 26, 2007 | 10:15 AM
Default Re: 91 ef hatch SHIFT FORK/LEVER HELP!!! have ne clue...any ideas? (Efkrew91hatch)
correction: i meant to say CLUTCH FORK/LEVER at the title sorry
Old Jun 28, 2007 | 05:24 AM
bump...
is it throwout bearing or the springs on the clutch fork near the throwout bearing
Old Jun 28, 2007 | 05:33 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
This should be easy to figure out. you are not going to fix it w/o taking the tranny off again. I would start by making sure you put the clutch disc in correctly ( it only goes one way) and that the throw out bearing is moving freely.
Old Jul 2, 2007 | 06:54 AM
TRQLESS's Avatar
Your also supposed to buy the clutch for the trans, not the motor.
Your trans is cable, the clutch you ordered was hydro.
Old Jul 2, 2007 | 07:32 AM
cr-x-91's Avatar
A STAGE 4 ON A Z6...WHAT ARE U THINKING???????????? GO WITH A SPORT CLUTCH NOT STAGE 1 OR 2. UR CAR IS PROLLY STOCK I BET.
Old Jul 2, 2007 | 07:54 AM
Furyof4's Avatar
Default Re: (TRQLESS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRQLESS &raquo;</TD></TR><TR><TD CLASS="quote">Your also supposed to buy the clutch for the trans, not the motor.
Your trans is cable, the clutch you ordered was hydro.</TD></TR></TABLE>
^What he said.
hatchet_honda
Jan 30, 2010 02:22 PM
ErrorAccord
May 8, 2005 06:24 PM
JohnnyB70
15
Aug 30, 2004 01:12 PM
