Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 Element EX 4WD ABS Brake Bleed sequence...
Old Jun 26, 2007 | 10:04 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default 2003 Element EX 4WD ABS Brake Bleed sequence...
Can anybody with the OEM shop manual tell me the recommended sequence for bleeding the brakes of 03 Element EX 4WD w/ ABS? The owners manual says to replace the brake fluid in your car every 3 years, but doesn't give you the details of what order to do it in...
BTW: That old myth of farthest-to-nearest wheel from the master cylinder doesn't apply to any Honda I've ever worked on. So I'm only looking actual info directly from the service manual...
Thanks!
Old Jun 26, 2007 | 02:58 PM
Ross 2.0's Avatar
In a Junkyard near you.
LF RF RR LR
Old Jun 26, 2007 | 04:22 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Evil Monkey)
Hey thanks! Does the book mention anything special about bleeding the ABS system? Stoptech recomends you bleed twice and take the time to activate the ABS in between. The idea is to get fresh fluid into the ABS sytem, and get that old fluid out on the second bleed...
Old Jun 28, 2007 | 03:02 AM
Ross 2.0's Avatar
Default Re: (94eg!)
By flushing the brake fluid you are also flushing most of the ABS system. Unless you NEVER activate ABS I don't think that would be needed since it already cycles fluid during it's "self check".
But if you feel the need to it won't hurt.
Old Jun 28, 2007 | 07:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
Thanks. Your the man...
masospaghetti
Nov 23, 2016 05:10 AM
__oversea
Jul 6, 2008 07:51 AM
lowered94accord
Mar 30, 2007 11:55 AM
Kid1320
Jun 14, 2004 03:44 AM
MikeTV
Aug 5, 2003 02:23 PM
