not getting spark after turbo install.
Old Jun 26, 2007 | 01:51 AM
InTeGrA_bLazEd's Avatar
Default not getting spark after turbo install.
i just finished installing a drag gen 3 turbo kit into my 95 LS. for some strange reason now, the car is not getting any spark. before i even started installing the turbo, the car started up fine. i have checked all fuses, relays, and fuel. those are all good. the engine just keeps cranking but will not turn over. i was thinking that it might be an ignitor coil. any suggestions?
Old Jun 26, 2007 | 01:59 AM
turbod da's Avatar
Default Re: not getting spark after turbo install. (InTeGrA_bLazEd)
check and see if your spark plugs are fouled because of to much gas...had similar thing happen to me a while back..
Old Jun 26, 2007 | 04:42 AM
g0tgot's Avatar
i know you are supposed to gap the spark plugs at a diff size after install.....look into that....
Old Jun 26, 2007 | 08:22 AM
will that cause no spark though?
Old Jun 26, 2007 | 08:33 AM
DBAl's Avatar
Default Re: (InTeGrA_bLazEd)
Have you started it all since the new turbo?
Upgrade the spark plugs, it will be cheap, could help the problem, and will probably be needed down the road anyways.
Old Jun 26, 2007 | 08:51 AM
this is the first time ive tried starting the car since the turbo has been installed. the spark plugs were upgraded to ngk spark plugs
Old Jun 26, 2007 | 09:37 AM
jinteg730's Avatar
sounds like it could be the distributor, get out the multi meter and check where the power stops, check the wires going into the distributor and move on from there to locate your problem
Old Jun 26, 2007 | 10:05 AM
ok, i changed the ignition coil and it started right up. when i first started it, it idled fine. a minute or 2 later, the idle fluctuates from 700-1100 rpm. another problem is that there is smoke coming from the turbo. is this normal or what could it mean?
Old Jun 26, 2007 | 04:32 PM
DBAl's Avatar
oil leak
Old Jun 26, 2007 | 05:00 PM
thanks....now i have a leak in my oil feed line. it starts leaking right before the screw is. its not leaking from the turbo side but its from the end of the line where back of the block is. now i have to wait for it to cool down. remove that line again, right after i reinstalled the oil pressure sensor with teflon tape. i will let you guys know what the results are when i take it for a test run.
Old Jun 26, 2007 | 05:58 PM
DBAl's Avatar
Hopefully it is no big deal... it shouldn't be. Just make sure everything is tight
Old Jun 26, 2007 | 06:12 PM
im trying to figure out whether or not the oil feed line has a leak in it. is there a way to test for a leak? im trying to test it by blowing through the line, but i cant find a sure way to do it. im hoping that its not a big deal. i have already spent quite a bit of money on little extras and made a good amount of trips to the auto store.
Old Jun 27, 2007 | 10:53 PM
DBAl's Avatar
more than likely it is a loose fitting, or something along those lines. (No pun intended) Look at it while it is running, or just after you turn it off when the oil is hot and will leak more easily. You should be able to get a good idea of where it is coming from.
Old Jun 27, 2007 | 11:02 PM
numbnuts22715's Avatar
if you dont have the fitting with the concaved edges to fit the inside of the fitting right, then it will leak. I'm not sure if you understand what I mean by that, but i cant think of another way to explain it. But the fitting has to fit into the line perfectly. Also, teflon needs to be used pretty generously.
MBlake55
Feb 27, 2006 06:16 AM
B18B1DOHC
Nov 17, 2003 02:08 PM
Chip398193
Mar 18, 2002 12:31 AM
