rear disk brake swap for 92 civic
Old Jun 26, 2007 | 01:32 AM
dimid17's Avatar
Default rear disk brake swap for 92 civic
hey everybody...
i have a 4dr 92 civic lx with drums in the rear... i want to convert it to disk brakes in the back...i have a set of disk brakes from a 92 integra with the e-brake likes still intact, as well as the proportioning valve and the brake master cylinder from a 92 integra coupe a friend of mine crashed and i pulled it all off there.....
Can I do this swap, will it all just bolt up? If not what else do i need to make it work?
All help is very appreciated.
thanks
Old Jun 26, 2007 | 01:40 AM
BlueIntegraBoy's Avatar
Default Re: rear disk brake swap for 92 civic (dimid17)
The rear discs will swap over. You won't need the prop valve (only if upgrading fronts to 94-01 Integras) or brake master. You'll need ebrakes cables from 92-95 Civic EX sedan.
susy76
30
Sep 10, 2012 11:44 PM
94gsxturbo
May 16, 2007 04:26 PM
mj1813
Dec 12, 2005 09:18 AM
integra-dc2
Jan 23, 2003 02:39 AM
