3" exhaust on a DA?
I know its definitely not optimal to put a 3" exhaust on a n/a car but how bad is it exactly? Like will it really kill my low end that bad? Will it be very noticable? The reason why I'm thinking of doing it is because I just swapped a new B18B in the car and my next project is now boost. But I'm in need of a exhaust now and realisticaly I wont have my turbo kit put together and installed for about a year or so. I already ordered a Skunk2 3" muffler and I was just planning on having a 2.25" catback bent from a shop and have them flare the end out to put the 3" muffler on. But I recently found a local guy that does mandrel bending (rare around here) but its kinda spendy so I wouldnt want to get it done twice. So I'm thinking about just getting the full 3" mandrel bent catback put on now since I need a new exhaust so bad. But I'm wondering how bad it is exactly and how much power I'm going to loose? If its serously going to bog down the motor I'm not going to do it.
3inch is Way Over Kill. You Will lose Power.
2.5 inch exhuast on a da. er anyhonda Is good for 500whp.
And then its time to upgrade.
But on Hondas you need some back pressure.
2.5 is most. n/a Id say 2.25
imo
imo
if you are running a hi comp NA motor maybe with ITBS then u will need 2.5.
and you need 3 if you have a huge turbo setup. But for a slightly built or modded car a 2.25 is all you will need.
Did you guys miss the fact that I will be boosting? I only plan on running it like this as a temp set-up because I need a exhaust now and dont feel like paying for 2 exhaust when I go to 3" later when boosted. And I dont know what you guys are smoking, but 3" is not overkill for boost. I plan on doing around 12-14psi and hopefully seeing 300 to the wheels. I could use 2.5" but 3" will alow the turbo to spool faster and its certainly not going to loose power vs. 2.5".
All I'm wondering is how bad is it exactly? Ive heard you will loose **** loads of power down low but I'm not sure how much I actually believe it. Ive driven my car open header before on the way to a exhaust shop after a swap and didnt really noticed any difference at all. And nothing has less back pressure than a open header! Like I said, I know its by no means ideal but it will be needed when I boost so I figure I might as well do it now since I need a new exhaust anyway. I'm just trying to figure out much it will effect me exactly until I can boost. I wont do it if it will really mess with the motor but I'm thinking open header isnt that bad and a 3" exhaust has to be better than that. Would really like to hear from someone who has driven a basically stock n/a motor with a 3" exhaust.
imo
imo
Yep, I want backpressure.
Punch yourself in the face now and when your vision clears, read.
Advanced Exhaust Tech 1
Advanced Exhaust Tech 2
Originally Posted by TeamIntegra
3. Myth 3: I Need A Little Bit of Backpressure For Midrange Power
THE MIGHTY BACKPRESSURE MYTH:
You want zero backpressure not some backpressure as you may sometimes hear from a salesman or an oldtimer domestic V8 hot rodder.
Stock backpressure is around 16 psi in a GSR. Good aftermarket exhausts yield 2-5 psi backpressure. "Bolt-ons only" engine packages, in the past, used exhausts with some backpressure, since there is this incorrect belief that having a little backpressure prevents the fresh air/fuel from shooting into the header at cam overlap (when both the opening intake valve & the closing exhaust valve are simultaneously, partially open). The backpressure supposedly "pushed" the fresh air/fuel back into the combustion chamber rather than having it go into the header. This shooting of fresh air/fuel from the intake manifold and intake port into the header cannot happen at cam overlap, since the pressure inside the header is already much higher than on the intake side , even when there is zero backpressure.
In reality, having more backpressure reduces the difference between the higher pressure in the head's exhaust port and lower pressure in the header and cat. You need this difference in pressure going from the head to the exhaust system or "pressure gradient" to keep the exhaust flow speed or energy at a high level. Having some backpressure during cam overlap and the exhaust stroke means that the exhaust gas must now push against something and therefore, this backwards force slows exhaust gas down.
This need for backpressure no longer exists when you have a properly tuned (timed) engine and a good stepped header. In fact, increased backpressure may lead to backwards flow or "reversion", where the exhaust gas travels backwards into the combustion chamber and dilutes the fresh intake charge at cam overlap. At the very least, it slows exhaust flow velocity or energy and prevents the creation of a vacuum for scavenging.
So please ignore the obsolete "you should have at least some backpressure" sales pitch. It's all about the creating high exhaust flow velocity/speed or energy leaving the exhaust port, in order for the header-cat-exhaust SYSTEM to do it's job properly (i.e. remove all the burnt exhaust gases and help pull in fresh intake charge by scavenging at cam overlap) and make power for you.
Regarding the backpressure issue:
Many people use backpressure to get midrange driveability at the sacrifice of lower power potential at the upper powerband rpms. Using back pressure is the wrong way to build a high performance exhaust system. The exhaust system should extract the exhaust gas from the header, to minimize parasitic pumping pressures.
The proper way to make an exhaust system that will act as an extractor is to properly size the tubing so that the the exhaust gas' flow velocity creates a "vacuum" behind the header.
Also, you have to realize that making a sytem which provides the best performance at all throttle positions and all powerband rpm ranges is next to impossible. There's always going to be a compromise and giving up some optimal power potential in one area of the rpm range.
You must tune the exhaust size/length for the throttle positions and rpm ranges where you want the most performance knowing that you'll sacrifice performance at the other end of the rpm range.
C. SUMMARY
If the exhaust has the design characteristics you want and is cheaper, get it. Please try not to be hooked by a salespitch or brand name hype.There's not much separating exhausts these days in terms of performance and design features for 2.25 to 2 3/8 in. straight-through designs. They are all pretty much identical.
The trick these days is finding a 2.5 in. diameter exhaust for the longer hybrid 4-2-1 and traditional 4-1 headers with bigger JDM-style 2.5 in. collectors.
In summary, plan where you want your peak torque will be and how wide your power band will be along the rpm range. Then choose a header-cat-exhaust system with the design characteristics that facilitates that goal.
You may get more midrange power but give something up at the top rpms.
Or the opposite, you can plan that you want more power in the upper rpms with some compromise losses at the midrange rpms.
Remember, if you get more midrange with some exhaust backpressure (the old backpressure myth) in a "bolt-ons only" engine package, ask yourself: what is the loss in hp at the upper rpms with more backpressure? And will this loss in power up top be acceptable to you?
C. SUMMARY
Read those links and stop with the back pressure crap.
Finally, someone that sees the point that backpressure is NOT a good thing. You don't need backpressure at ALL. What you need is a proper sized exhaust to allow things to flow better. But too big of an exhaust pipe will disrupt this. I'll go find a link of what I mean
Your not going to loose a bunch of power by putting the 3 inch exhaust on. If you want to see what it will feel like, run straight header for a couple days, thats pretty close to how a 3 inch exhaust is going to perform but the exhaust will probably be quiter.
elohel
Honda Civic (2006 - 2015)
10
Nov 1, 2007 12:17 PM
MassScene
Mar 8, 2005 06:57 AM
