'03 TL, how to remove the radio?
i just looked this up the other day actually....
can't locate the instructions on my home PC, but there are screws at the corners behind the wood trim that runs up the sides of the center console, also the CD tray comes out with it (uless your a navi then the climate control comes out with it)
becareful removing the trim pieces (they pry off with a screw driver, cover it with a rag so you dont scratch anything.
I think that was basicly it.
if you need more help ill try harder to locate the removal instructions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveng »</TD></TR><TR><TD CLASS="quote">Hey everybody, could you please give me a detailed step-by-step walkthrough on how to remove the radio? I need to retrieve the serial #, thank you!</TD></TR></TABLE>
well i just remoted my amp through my radio fuse which should be located in the bottem left side of the drive side but i did it on a 04 TL so i think it should work on a 03......but it's best if u do it throught ur radio
No need to do that! Just look at the glovebox side- you might be lucky and they posted the radio code there. CAll 1-800-382-2238 acura customer service and they will give you the code to unlock your radio for free.
GetawayInMoscow
May 13, 2005 08:38 AM
