Will stock ITR valvesprings work with Skunk2 pro stage ones?
Old Jun 25, 2007 | 08:34 PM
motormike40's Avatar
Default Will stock ITR valvesprings work with Skunk2 pro stage ones?
Are the stock valvesprings stiff enough for the Skunk2 pro stage ones?
Old Jun 25, 2007 | 09:42 PM
sPaRk'iT's Avatar
Default Re: Will stock ITR valvesprings work with Skunk2 pro stage ones? (motormike40)
Ooppss my bad i didnt read it carefully, nope Pro series you'll need stronger valvesprings.
Modified by sPaRk'iT at 9:18 AM 6/27/2007
Old Jun 25, 2007 | 10:59 PM
martyball619's Avatar
Default Re: Will stock ITR valvesprings work with Skunk2 pro stage ones? (sPaRk'iT)
no they are not.. the pro series are too aggressive. u need aftermarket valvesprings
Old Jun 26, 2007 | 02:29 AM
What do you recommend?
Old Jun 26, 2007 | 10:56 AM
Default Re: (motormike40)
if ur gonna get the skunk2 pro cams then why not get the skunk pro valvesprings along with it?
Old Jun 26, 2007 | 01:50 PM
OC Geezer's Avatar
Default Re: (DC2SiR)
He's probably got a hookup on the ITR's.
Old Jun 26, 2007 | 01:55 PM
Default Re: (InLtegSra94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLtegSra94 &raquo;</TD></TR><TR><TD CLASS="quote">He's probably got a hookup on the ITR's.</TD></TR></TABLE>
the ITR's are stock.. they are too weak for the pro series
Old Jun 26, 2007 | 04:47 PM
B18cya00's Avatar
Don't get pro 1's JDM ITR Cams are way better than the Skunk2 Pro 1's. It is proven look for other posts but I posted a dyno n 3 ppl sayn how they wasted there money on them when the ITR's give out more power. And my good buddy is sponsored by Skunk2 and he got A few Pro 1's 2's n 3's for free n put them against the ITR's on the dyno n the 1's were horrible! Hopefully You didnt buy them already man! Good Luck...
Old Jun 26, 2007 | 08:22 PM
doood's Avatar
been there done that
Default Re: (B18cya00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT &raquo;</TD></TR><TR><TD CLASS="quote">Yes</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cya00 &raquo;</TD></TR><TR><TD CLASS="quote">Don't get pro 1's JDM ITR Cams are way better than the Skunk2 Pro 1's. It is proven look for other posts but I posted a dyno n 3 ppl sayn how they wasted there money on them when the ITR's give out more power. And my good buddy is sponsored by Skunk2 and he got A few Pro 1's 2's n 3's for free n put them against the ITR's on the dyno n the 1's were horrible! Hopefully You didnt buy them already man! Good Luck...</TD></TR></TABLE>
wtf are you two smoking?
Old Jun 26, 2007 | 09:44 PM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
wtf are you two smoking?</TD></TR></TABLE>
x2..
Old Jul 3, 2007 | 02:26 PM
B18cya00's Avatar
Default Re: (doood)
Im not smoking **** I saw them do it n saw the dynos and have seen other dynos on H-T with the same comparison n looks u guys r the ones smokn some ****!
Old Jul 3, 2007 | 06:12 PM
Im not smoking **** I saw them do it n saw the dynos and have seen other dynos on H-T with the same comparison n looks u guys r the ones smokn some ****! </TD></TR></TABLE>
lol ur a dumbass.. the pro series cams is more aggressive than the OEM type R cams. ./ thread
Old Jul 4, 2007 | 05:00 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cya00 &raquo;</TD></TR><TR><TD CLASS="quote">Im not smoking **** I saw them do it n saw the dynos and have seen other dynos on H-T with the same comparison n looks u guys r the ones smokn some ****! </TD></TR></TABLE>
so you're seriously telling me itr cams make more power than pro1's? ****, better tell the guys in the all motor forum to switch back to smaller cams if they want more power.
Old Jul 6, 2007 | 11:28 AM
SuckMyDOHC's Avatar
I've seen tons of dynos.... the pro 1's are more aggressive than stock ITR cams.
Old Jul 6, 2007 | 01:05 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
some one in the itr forum did the pro 1 comparison almost 10 whp gain, but dont know if that was with higher compression pistons.
Old Jul 6, 2007 | 05:05 PM
1.8L_allmotormilitia's Avatar
wtf r u saying? how the *** does oem cams a little bigger then stock gsr cams make more power then skunk2 pro 1's when the vtec lobe/idle lobe are the size of the *****?
TYPE-R#945
Apr 9, 2008 08:15 PM
cb169
Mar 31, 2008 07:47 PM
poormans_typer69
Oct 1, 2007 03:01 PM
motormike40
Jun 26, 2007 06:16 AM
finest_GSR
May 26, 2006 03:33 PM
