Crap spark wires causing a misfire?
Old Jun 25, 2007 | 08:03 PM
utn's Avatar
utn
Default Crap spark wires causing a misfire?
Can crappy spark wires cause a misfire? I bought $20 napa brand wires and my car doesn't run so smooth... Got new plugs too, but dont know whats going on, I cant fix the friggen' car
Old Jun 25, 2007 | 08:14 PM
ke98248's Avatar
Default Re: Crap spark wires causing a misfire? (utn)
Get NGK spark wire/plugs FTW
Modified by ke98248 at 9:39 PM 6/25/2007
Old Jun 25, 2007 | 08:30 PM
JasonGhostz's Avatar
There's a chance that your Wires are Arcing. I don't know how good the insulation is for the $20 NAPA Wires, but that might be a contributor. You can check for this in a dark garage. Turn off the lights, Turn on the engine, and watch your wires closely (stay away from moving parts!). If it's bad enough, it might cause a "misfire"... Keep your garage door open, suicidal maniac!
Just throwin it out there. GL, and let us know!
JasonGhostz
Old Jun 25, 2007 | 08:38 PM
utn's Avatar
utn
Default Re: Crap spark wires causing a misfire? (JasonGhostz)
I'm quite sure the insulation is poor - ever since the install I've had radio interfearance at high rps, I dont know what else could be the culprit.
Old Jun 25, 2007 | 08:39 PM
Syndacate's Avatar
Absolutely they can.
~$4/pc NGKV-Power plugs with Bosch ~$50 wires - Autozone rotor and cap and you'll be set.
Any misfires after that and I GUARANTEE it's something else.
Old Jun 25, 2007 | 11:38 PM
utn's Avatar
utn
Default Re: Crap spark wires causing a misfire? (Syndacate)
should I go with bosch or ngk?
utn
Jun 26, 2007 01:36 PM
sLo h22
Mar 11, 2006 10:47 AM
shivic
Jan 4, 2004 04:36 PM
accord94
Apr 17, 2003 06:49 AM
integra7
Jul 30, 2001 06:41 AM
