b18b w/ b20 head?
Old Jun 25, 2007 | 05:45 PM
eglslsd's Avatar
Default b18b w/ b20 head?
some one told me that i could use a p8r head on a b18b with out sleeving my block ist it true
Old Jun 25, 2007 | 06:04 PM
unknown0001's Avatar
Default Re: b18b w/ b20 head? (eglslsd)
lol why would you need to sleeve the block to use a b20 head?
yes the p8r head is a nice *upgrade* over the factory b18b head
doood's Avatar
been there done that
yes
Old Jun 25, 2007 | 07:08 PM
non-VTEC's Avatar
Default Re: b18b w/ b20 head? (doood)
you guys sound sure that you can run a 84mm chamber p8r head on a 81mm bore block.........how would that head gasket seal up?
even if you used a 84mm gasket i don't think the engine would run right since the quench area of the chamber would be overtop of the deck of the block by 3mm..........
anyone else wanna add some input?
Old May 27, 2008 | 11:05 AM
Jacknimble's Avatar
Default Re: b18b w/ b20 head? (non-VTEC)
I am running a b20 head on my b18a1 with b18 head gasket. Runs ok. but smokes alot and burns through oil. When I did the rebuild I put new rings, bearings, valve stem seals, and valve lash. Think it's the combustion chamber on the head compaired to the sleeves makeing the problem. I'm building a b18a1 head to put on and see if it changes things. But with this and 89 octane in North New Jersey made 120hp and 118ftlbs on dynopacks.
juicedricer
19
Jan 19, 2011 08:37 PM
DAfireman
Nov 25, 2004 10:17 AM
fasterthanU
Jun 4, 2004 04:24 PM
LSBeast
10
Sep 17, 2002 06:44 PM
Chuji
Sep 6, 2001 05:25 PM
