wiring knock sensor on b16a
i have a b16a with the stock obd0 ecu and i was wondering where i wire the knock sensor the the harness.
the car the swap is going into is a 88 hf. with the stock harness as well.
if anyone could tell me where to tie the knock sensor wire into the main harness would help.
did you ever find out if do let me kno pleaseeeeeeeeeeeeeee im stuck with the same problem on a b18a1 going into a 95 civic with the 0bd1 civic harness??thank you
theres wiring diagrams/ the full helms manual on this dudes page. im most definitely sure its in there.
i havent done mine yet, im still running OBD0, but i will need to do mine hella fast cuz i gotta go to OBD1 and pass the state ref.
http://www.deliii.com/
I have a spoon sports OBD1 ecu in my -91 CRX (OBD0) and since B16A1 has no knock sensor originaly, it's installed afterwards.
In OBD1 it's pretty simple, just run one wire from the ecu to the sensor and bolt the sensor to the car and thats it.
I have some pictures for you.
mustninty20
Dec 19, 2008 03:36 PM
WOODman
Oct 7, 2005 07:09 PM
