Anyone running w/o torque mounts?
Old Jun 25, 2007 | 05:09 PM
GetawayInMoscow's Avatar
Default Anyone running w/o torque mounts?
I was thinking of getting the stiffest Innovative mounts and just ditching my torque mounts.
Does anyone do this? B-series into an EG. I'm looking at making some decent power here.
Old Jun 25, 2007 | 05:14 PM
DaveF's Avatar
Default Re: Anyone running w/o torque mounts? (GetawayInMoscow)
you are asking for problems not running them.
Old Jun 25, 2007 | 05:18 PM
1992Si's Avatar
We just had solid mounts made for our D series. We went form the lower crankshaft side mount, the one that holds the A/C compressor and bottom mount and had a plate made to go forward to the traction bar mount where the factory tie down bolted to.
On the tranny side I had the guy make a "L" style brace with a gusset. and bolted it to the 3 tranny mount bolts on the front side of the tranny and to the tie down bolts.
Modified by 1992Si at 9:35 PM 6/25/2007
Old Jun 25, 2007 | 05:22 PM
RPRacing's Avatar
if you can run them, run them. it will prolong the life of your new mounts, and help with traction/wheel hop issues.
Old Jun 25, 2007 | 08:42 PM
taggart_lumpy's Avatar
we dont hace the ac bracket on our car
for now that is
Old Jun 25, 2007 | 10:16 PM
Timmay's Avatar
Default Re: (taggart_lumpy)
i dont run them on my car but its not turbo'd.. if you have the 3 solid mounts i wouldnt worry about it
ive seen tons of cars just run the after market mounts and no front tq ones
Old Jun 25, 2007 | 10:32 PM
Boner_Ben's Avatar
Default Re: (Timmay)
I've never ran them but I plan on making solid torque mounts or making a front motor mount with the traction bar.
Old Jun 26, 2007 | 01:22 AM
94turboeg's Avatar
Default Re: (Boner_Ben)
HOw do you run a ATI balancer or SFI balancer with the torque mounts?
Old Jun 26, 2007 | 02:42 AM
1992Si's Avatar
Do what Francisco from RPRacing say's. I've seen what can happen. He has first hand experience.
As for ATI or SFI balancer's, how big are they? the lower mount bracket is pretty far from the crankshaft.
The plate we had made runs forward and is 3/16" thick.
Old Jun 26, 2007 | 03:36 AM
DaveF's Avatar
Default Re: (94turboeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94turboeg &raquo;</TD></TR><TR><TD CLASS="quote">HOw do you run a ATI balancer or SFI balancer with the torque mounts?</TD></TR></TABLE>
how dont you ?? the balancer will not hit the mount.
Old Jun 26, 2007 | 03:58 AM
swapit's Avatar
Default Re: (dturbocivic)
i couldnt run the ac bracket my ati dampner hit it but i do have full race pro am bars with the torque mount and i do run the trans side,i would always try to run all mounts poss. seen a engine mount break the block twice and a t mount break the trans from not using the torque mounts.jus my two cents.
Old Jun 26, 2007 | 04:03 AM
DaveF's Avatar
Default Re: (swapit)
how bad did it hit ? real bad or could have shaved the mount slightly for clearance? i havent tried to install the stock ac bracket, but i didnt think it goes back like that.
either way, fabbing a new mount is not hard. but you already have the FR bars with mount so that takes care of that.
Old Jun 26, 2007 | 04:29 AM
vaporboy12's Avatar
my ati damper fit fine say 2 to 3 inchs of clearence to the front mount
Old Jun 26, 2007 | 04:31 AM
ALL IMPORT's Avatar
i have never ran torque mounts. making aroudn 700whp, i cut 1.6's .
this has been for about almost a year.
BUT the stud for the tranny mount has broken of & i had to make a new one out of raw stell rod. bit i think that hapend from when ive taken the trans out about 15times to fix broken gears. must of hit somethintg with it . i do want to put the torque mounts back in just to lazy. i would have to fab some stuff up due to turbo ect..
Old Jun 26, 2007 | 04:34 AM
vaporboy12's Avatar
Default Re: (ALL IMPORT)
I use to not run them and put some inline torque mounts in the shifts were so much smoother
Old Jun 26, 2007 | 04:42 AM
DaveF's Avatar
Default Re: (vaporboy12)
hey B. are those the solid billet aluminum ones ?
Old Jun 26, 2007 | 04:46 AM
vaporboy12's Avatar
no they are solid urethane mount with a stainless steel housing... avid makes the solid billet alumi. ones
Old Jun 26, 2007 | 04:53 AM
DaveF's Avatar
ahh so the inline pro ones are similar to the old jim-fabs ?
either way those lowers (non oem) will do a hell of a better job keeping the engine in 1 spot
Old Jun 26, 2007 | 05:00 AM
vaporboy12's Avatar
im guessing they are the same never seen the jim fab ones before..
Old Jun 26, 2007 | 07:08 AM
.CUBISH.'s Avatar
avid mounts with trq mounts also.. ati damp. fit fine..
motor def moves a lot less with the trq mounts in even if u have stiff aftermarket mounts to motor is still going to lift.
Old Jun 26, 2007 | 08:08 AM
Boostfed's Avatar
New User
Default Re: Anyone running w/o torque mounts? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you are asking for problems not running them.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you are asking for problems not running them.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you are asking for problems not running them.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you are asking for problems not running them.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you are asking for problems not running them.</TD></TR></TABLE>
Old Jun 26, 2007 | 08:20 AM
ALL IMPORT's Avatar
Default Re: Anyone running w/o torque mounts? (Boostfed.com)
can u repeat that please
Old Jun 26, 2007 | 08:25 AM
vaporboy12's Avatar
Default Re: Anyone running w/o torque mounts? (ALL IMPORT)
very creative post terry
Old Jun 26, 2007 | 08:26 AM
Arturbo's Avatar
Better than steak
25 Year Member
i dont run them, but would like to run a solid set up. I used to have the JDM aluminum mount AC. i also run the FR pro-am which attaches to the block.
Old Jun 26, 2007 | 09:03 AM
Innes's Avatar
Default Re: Anyone running w/o torque mounts? (Arturbo)
i would recommend running them -- CFT can't run them due to their intercooler pipe routing or something and they get a lot of movement for the other 3 mounts and have had issues breaking the mounts -- i believe due to not having the front torque mounts installed -- they have since remedied this problem from my understanding
whereas we have always run the 3 engine mounts and the torque mounts and get no movement at all -- avid racing all the way around including torque mounts -- work great -- and we run the ATI dampener with no clearance issues either, installs just fine
