itr 5 lug ??
i thinking of getting JDM itr 5lug, i have a couple question my axels are 32mm and the jdm itr ones are 36mm what would i have to do to reuse my axles? Get usdm wheel bearings? Also the front fork for the suspension would that also need to be changed? I have a 96 LS 2dr
From: Dont say my car is topless say the titties is out
When people usually buy 5 lug, it comes with everything, including the front forks, which makes it easier to swap on. As for the axles, if you want to reuse your stock ones, you'd have to use the 36mm outer and the 32mm inner. If your not wanting to go that route, try some websites like jdmtheory, for the axles.
the forks are the same just get jdm 36mm axles the only way to use your stock 32mm axles is to convert yours to 36mm outers, or get us hubs, get new bearings, and use yous stock knucks and throw the jdms away
Do you just HAVE to have the original parts off of an ITR, or would you settle for ITR size brakes, better calipers and still be 5 lug?
You can piece together a better brake system than the OEM ITR using Integra, Prelude, CRV and Acura Legend parts, the acura legend parts being the dual piston calipers.
Here's a compilation of links and misc info I compiled on it.
Originally Posted by me
500http://www.gs-r.com/phpBB2/viewtopic.php?t=5477
So you want more braking power from your integra without having to shell out $1200 for a big brake kit? Heres your chance to upgrade to a 11.1" disc with 2 piston calipers and bigger brake pads. So you have more fiction with the bigger pads, more clamping force with bigger calipers and more leverage on the wheel with bigger rotors, which makes for an impressive upgrade.
Ok first of all you need:
- 11.1" rotors - Brembo blanks redrilled from a prelude vtec(94-96), accord V6 wagon(96-97), or a Type R. I believe any honda 11.1" rotor will work(RSX-S, TL, etc) but Ive been told the offset isnt right and you would have to grind more from the caliper. You will also need to get the rotor redrilled to 4X100 in order to fit on the integra(no honda that i know of with an 11.1" rotor has the 4X100 lug pattern). I believe the new EP3 (only 02-03s I think) are a 11.1" rotor w/ 4 lug.
- Calipers - $120-200 depending on condition etc, the 94-95 legend GS 2 pistons work great, the NSXs are prettier with the NSX in the side of them, but they are actually smaller 40mm and 34/36mm pistons...depending on year model) vs the legends at 42 and 38mm. Ofcourse the ITR has the 1 piston setup.
- Brake fluid - $varies As always when you do your brakes(new pads or otherwise) you will need a bottle of brake fluid.
You will need to grind off material on the new caliper mounting bracket(no matter if you get the ITR, Legend or NSX calipers). I took an angle grinder to mine, but any sort of sanding or grinding tool should work. Grind the mounting bracket on the back side of the caliper(as seen in #2 and #3). You will more or less grind the lip off(that is circled on #3) so that it is flush with the rest of the bracket.
You can either bolt the Left caliper on the right side and the Right on the left, so that the bleeder nut is pointed up(its backwards because on the legend the caliper was actually on the backside of the wheel vs the front). If you dont do this, then you will need to place something in the caliper to hold it open, then go ahead and bleed it off before you place it on the car. Once it is upside down you will NOT be able to bleed off the air in the line because it raises to the top and the bleeder is on the bottom(thus your brakes will feel squishy).
http://hondaswap.com/hybrid-eg...18727/
This is using Australian delivered Honda parts- The v6 accord seems to have the exact same brake specs as the ITR and the Prelude VtiR.
I have recently up graded my stock 10.5 inch JDM SiR brakes for 11.1inch brakes off an Accord. The brake discs and callipers were the exact same as those of a type R integra. I just had to redrill discs and shave 1.4mm off the brake calliper mounts.
Well after spending 4 hrs in a honda parts warehouse I have these useful tips.
Honda HRV (mini SUV) front hubs (5 stud) press straight in to the honda civic knuckles and make the disks and calipers from the HRV (same part numbers as CTR/ITR) a bolt on proposition.
Honda accord prelude rear hubs will go onto the civic if you extend the factory stub axle with a screw on extension. An extension allows you to bolt on the accord/prelude 5 stud hub disc and calliper. Again the same specs as ITR.
Hope this helps people comtemplating the swap.
Most cost effective is to just bolt on the redrilled accord front disks and shave some off the calliper bracket (1.4mm).
Parts that are proven the same:
4th gen front knuckle - 5th gen front knuckle - 98 CL 4 cyl front knuckle
4th/5th gen front wheel bearings - 98-99 Acura CL 2.3 front wheel bearings
98-02 Accord V6 front calipers - 98+ Integra Type R calipers
98-02 Accord V6 front rotors - 98+ Integra Type R front rotors
98-02 Accord V6 rear rotors - 98+ Integra Type R rear rotors
Parts that are not the same:
4th gen rear knuckle - 5th gen rear knuckle
98 4cyl Hub - 98-99 CL 4cyl Hub
SETUPS:
lightningd - 5th gen
5th gen wheel bearings
98 2.3 4cyl CL hubs (Acura P/N: 44600-SY8-A00) (NOTE: comes with studs)
98 2.3 4cyl CL 10" Brembo Blank rotors.
5th gen calipers
Axxis Ultimate Brake pads
ATE SuperBlue DOT 4 Brake Fluid
zebro racing
Brembo OEM size cross drilled rotors
Steel braided lines
kapao818 - ??? gen
Stainless Steel Lines
Motul RB600 DOT Brake Fluid
Brembo Blanks
EBC Greenstuff Pads
Gennady - 4th gen Prelude Si 4WS
93 Prelude VTEC 11.1" Rotors
94 Legend GS 2-piston Calipers
93 Prelude VTEC 23T Caliper Brackets
93 Prelude VTEC 1" Master Cylinder
aero3685 - 4th gen
99 Acura CL 2.3 Hub
99 Acura CL 2.3 Rotors
99 Acura CL 2.3 Bearings
91 Accord Calipers
91 Accord Pads
Chris - 5th gen EX
5 lug conversion
94-95 Acura Legend dual-piston front calipers
94-97 Honda Accord rear calipers
98+ Integra Type-R front and rear rotors
GZERO - 5th gen
95-97 Accord V6 Rotors (11.1")
95-97 Accord V6 Calipers (came refurbished with brackets)
95 Accord Wheel Bearings
phatdoughnut - 4th gen (91 non abs)
99 CL front knuckles (minus ABS)
94 Prelude VTEC 11.1" OEM front rotors
94 Prelude VTEC 23t front calipers
93 Accord Ex rear discs
94 Prelude Front oem pads
93 Accord Oem rear pads (minus ABS)
Here is a document created by Chris:
Single-piston brake upgrade:
OEM Honda front calipers from 95-02 Accord V6/wagon, 93+ Prelude VTEC, or 98+ ITR
OEM Honda 25T brackets
rotors for 95-97 Accord V6/wagon
Dual-piston brake upgrade:
OEM Honda front calipers from 94-95 Legend GS Sedan
OEM Honda 25T brackets, 28T with caliper may work too
simple rotor-over-hub conversion:
OEM Acura 98-99 2.3 CL front hubs
rotors for 98-99 2.3 CL
pads - any options
Optional 94-97 Accord front wheel bearings
Single-piston brake upgrade with rotor-over-hub conversion:
OEM Honda 23T brackets
rotors for 98-99 Acura 3.0 CL or 93-96 Prelude VTEC
pads - any options
Dual-piston brake upgrade with rotor-over-hub conversion:
pads - any options
Single-piston brake upgrade with 5-lug conversion:
OEM Honda 95-97 Odyssey front hubs
OEM Honda 95-97 Accord V6/Odyssey front wheel bearings
OEM Honda 95-97 Accord V6/Odyssey front knuckles
OEM Honda 97+ Prelude rear hub/bearing assembly
front and rear rotors for 98+ ITR (rear is also 98+ Accord V6)
Dual-piston brake upgrade with 5-lug conversion:
http://www.hondasociety.com/bo...21710
$200 for rear 97 prelude hubs (brand new)
$80 94 Legend GS front calipers left and right
$75 97 Prelude Front rotors
$65 98 Accord v6 rear rotors
$10 97 Prelude calipers w/ brackets ( traded these in to get my core back from legend calipers. And kept the bracket)
$140 Goodridge stainless steel brake lines
$10 brake fluid
Front Upgrade Parts list:
CRV 5 lug Hub
ITR/Prelude Rotors/Accord V6 $100.00
94-95 Acura Legend Calipers (same as NSX)
Rear Brake Upgrade:
Prelude/Accord/CRV rear Hub: Prelude w/Bearing $141.00 Ea.
Stub axle extension??
Prelude/Accord Rotor
Prelude/Accord Caliper
SETUPS:
5th gen calipers
zebro racing
Steel braided lines
kapao818 - ??? gen
Brembo Blanks
EBC Greenstuff Pads
aero3685 - 4th gen
99 Acura CL 2.3 Hub
91 Accord Calipers
91 Accord Pads
Chris - 5th gen EX
5 lug conversion
GZERO - 5th gen
pads - any options
pads - any options
pads - any options
$10 brake fluid
CRV 5 lug Hub
Rear Brake Upgrade:
I want to do it for the following reasons:
16x7 5x114.3 Regas
16x7 5x114.3 RG's
900+ for used "JDM" conversion.
I just want to build a working 5 lug with new parts. And if I could do it cheaper and with better brakes, thats even better.
16x7 5x114.3 Regas
16x7 5x114.3 RG's
Well the above info can get you better brakes for cheaper and nobody will know the diff.. save for the calipers.
You just won't be " True" JDM. You'll be a poser
Which is ok. You'll have bigger brakes and have less dough invested than them too.. WHich in my eyes, means your SMARTER.
RhdRicheeee
Nov 21, 2005 04:06 PM
