need help with radio 99 accord
Old Jun 25, 2007 | 04:07 PM
tristantiojanco's Avatar
Default need help with radio 99 accord
i need help intalling an aftermarket radion on 99 accord ex v6 coupe...it would be a big help with pictures thank in advance
Old Jun 25, 2007 | 05:35 PM
naoandlata's Avatar
Default Re: need help with radio 99 accord (tristantiojanco)
Its easier to install an aftermarket radio with a wire harness and you might need a single bin tray too.
Just unscrew two screws on the bottom dash part of the radio then use a flathead to remove the light. Theres a screw behind that clock and then the plastic dash should come off and the rest should be simple
Old Jun 25, 2007 | 06:11 PM
arielb1's Avatar
Default Re: need help with radio 99 accord (naoandlata)
Check it out...I had Circuit City do it. I was free with a purchase of a radio. I had them install a jack for the ipod as well. Its pretty awesome. Just do your homework first. By the way, if I sell the car, they will put the old radio back at no charge. They had the wiring harness and bin. Check out crutchfield.com. You may find directions for your year of car and radios that will work with an ipod. Oh, one last thing, the ipod gets charged automatically and you control it via the console of the radio...again do your homework. Mine for instance starts at the same song if I turn off the car. I heard this was fixed. What ever you do, dont install a cd changer. It would be a waste of money.
good luck...good karma
Ehop
Jan 24, 2010 10:53 AM
crc13
Mar 12, 2008 05:26 AM
Civiclized
Jan 13, 2007 09:25 AM
navypeds
Mar 29, 2005 08:23 AM
