A/C Compressor will not come on
Old Jun 25, 2007 | 02:45 PM
Accordn95's Avatar
Default A/C Compressor will not come on
I have a '95 Ex 4cyl VTEC and I cannot get my a/c compressor to come on. All fuses are good and the relay going to the comp. is good, I get 12v to the relay, but not the compressor, the red wire from the relay connector is good, jump the compressor; it clicks, condenser fan comes on when a/c button is pushed and car does idle up, jumped pressure switch and compressor still doesn't come on. I am stuck at this point, can someone please help?
Old Jun 25, 2007 | 04:25 PM
hondadude's Avatar
Default Re: A/C Compressor will not come on (Accordn95)
When you jump the pressure switch and try to turn on the compressor, look to see if the clutch plate/disc is pulling into the spinning part of the clutch?
You are sure you are getting power to the clutch coil and it has a magnetic effect?
Often times the disc gets worn down where the 2 faces meet each other and you need to remove the clutch disc and take out one of the shims on the center shaft.
Another check;[not for the faint of heart] is to smack the clutch disc while the compressor is trying to run and see if it will stay engaged.
EcRzFinesT
Honda Civic (2001 - 2005)
19
Aug 11, 2015 08:20 AM
accord99power
Aug 18, 2012 12:30 PM
sonnyny
Honda CR-V & Element
Jun 10, 2012 10:07 AM
Bartman201
Aug 25, 2010 08:47 AM
Mackln308
Jul 30, 2010 11:34 AM
