Euro-R Piston rings and Bearings
Old Jun 25, 2007 | 01:36 PM
snowblind7x's Avatar
Default Euro-R Piston rings and Bearings
I have a Euro-R motor that i'm thinking about changing the piston rings and bearings on. How do i know which ones to get? There is so many options here: http://www.hondaautomotivepart...ISTON
Old Jun 26, 2007 | 11:36 AM
Default Re: Euro-R Piston rings and Bearings (snowblind7x)
bump
Old Jun 26, 2007 | 11:42 AM
xxmastermindxx's Avatar
as long as they're the right ones for your motor... you will need a set of main bearings, 5 pairs make a set. a set of rod bearings, 4 pairs make a set. and a set of rings for each piston.
there aren't really "options" on that page, as all those parts are used, its not pick and choose. but you should probably have your crank polished and measured so you put the right size bearings.
i'm in this process right now so i thought it would help
Old Jun 26, 2007 | 12:00 PM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">I have a Euro-R motor that i'm thinking about changing the piston rings and bearings on. </TD></TR></TABLE>
Why? Are they worn? burning oil?
As said by JG Luder(something to the nature of) Once you open up the bottom end of an H series motor, the reliability fairies fly away......
Don't mess with the rings and bearings unless you need to.
b18c5_ej8
Nov 26, 2011 05:07 PM
revlimitcrx
Mar 3, 2007 05:00 PM
