Popping Fuse 1
My car keeps popping fuse 1, the fuse for the turn signal and the reverse lights. Also control the cluster and the clock.
Well, I sorta need that stuff to you know, stay legal. What should I do to help solve this problem. The fuse pops instantly when I turn to the on position.
I was gonna check continuity to body ground from both sides of the fuse, to see which on has the short in it. Could a bad relay cause such failure consistantly. The fuse popped after a hard launch at the race track (2.0 60 foot, yay). It hasn't worked since.
GreenD16Y8
Aug 8, 2005 03:59 PM
