do the retaining rings come with the lower ball joint dust boots?
http://www.barancoacuraparts.c...7C005
i want to buy part #5 (51225-SR0-A01)... but don't know if it comes with the retaining ring that secure the boot. does anyone know if it does?
hmmm I would assume so, since it doesn't list them separately. It lists #9 as a circlip, which I guess is the same as the C-clip on the ball joint? Not sure what #17 is, I wonder why it doesn't list it...
You might want to just give Len a ring at Baranco, he can probably give you a more definite answer.
I believe there is supposed to be a c-clip that goes around the ball joint, AND some sort of separate clip that goes around the boot itself to keep it in place. That's what I noticed on my aftermarket replacement upper control arm ball joints.
What are you needing Reno?
yep, that's what i need.. the clip for the boot. i replaced the boot with an aftermarket boot and i want to replace that with an OEM one since i feel this aftermarket boot is too tall. the aftermarket boot has two clips, so i could probably use those, but i want to be confident on proper fitment.
check this website for parts. https://www.autopartswarehouse.com
D16SohcVtec
14
Apr 12, 2009 09:23 AM
B18EG6
10
Jan 23, 2006 03:20 PM
Rywire
Mar 11, 2004 12:21 PM
