Should I switch to Synthetic?
Old Jun 25, 2007 | 01:10 PM
m1ndless's Avatar
* B A N N E D *
Default Should I switch to Synthetic?
Is synthetic better for my car? Its a 95 accord, has about 138k miles. Will it run smoother? Does it really make a difference.
Old Jun 25, 2007 | 01:31 PM
92ACCORD_CB7's Avatar
Default Re: Should I switch to Synthetic? (m1ndless)
This topic have been already talked about on the Accord section. Here is the link:
https://honda-tech.com/zerothread/2019133
Read it and you'll find your answer to your question about Synthetic oil.
Old Jun 25, 2007 | 07:59 PM
Lubo_25's Avatar
you could switch to syn oil but i find once the mineral oil has been used for that amount synthetics burn off too quick...the metal has adopted to that type of oil makeup but thats my .02 cents...
Old Jun 25, 2007 | 08:54 PM
Bruce Banner's Avatar
Default Re: Should I switch to Synthetic? (Lubo_25)
I use syn at 190k.
WOrks great, smooth
Old Jun 26, 2007 | 03:21 AM
YeuEmMaiMai's Avatar
If youwant to use synthetic, it's OK. Unless someone can PROVE to me that my engine will definately last longer with synthetic and it costs about the same overall as dino oil, I'm sticking with dino oil.
I have NEVER had an engine fail due to oil problems and some of my cars have made it 200K plus with a 82 chrysler 5th avenue that had a 318cid motor that went 380K before the block cracked you could not really drive it anymore.
Old Jun 26, 2007 | 05:11 AM
TheMuffinMan's Avatar
He knows where you live!
^^ I agree, it's fine to do, but no real reason to
I switched to the "higher mileage" Mobil 1 oil 10w30 vs the 5w30
That's about the extent that I've done, no real reason to change over
Old Jun 26, 2007 | 10:37 AM
raceACCORDingly's Avatar
made the switch to a syn blend went the turbo went on.
deerman2701
14
Jan 11, 2012 07:58 AM
AuroraHonda
Sep 13, 2009 03:22 PM
HA0LEFIED
Honda Civic (2006 - 2015)
Nov 18, 2007 08:23 PM
goheel
Feb 20, 2007 03:24 PM
old_school_dohcvtec
Feb 10, 2005 06:03 PM
