starter? wtf is going on?
Old Jun 25, 2007 | 12:11 PM
YAH YAH's Avatar
Default starter? wtf is going on?
okay every about 10 start ups. it takes my car 2-3 times as long to start. u can hear it crank but it doesnt go. it doesnt happen all the time. prob bout every 2 days. do i need a new starter, distributor, tune up? plug wires. i replaced my spark plugs about 4k ago.
Old Jun 25, 2007 | 12:59 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: starter? wtf is going on? (chiboi800)
it might be your main relay giving out. Does it still turn over just doesnt start? As long as its still turning over than that rules out the starter. You sohuld inspect the cap and rotor and replace them if they look pretty worn, as long as the wires have no cracks you should be good.
Old Jun 25, 2007 | 01:01 PM
alexisthemovie's Avatar
could be that each time you are low on gas
Old Jun 25, 2007 | 09:34 PM
YAH YAH's Avatar
yeah happens more often when i am lower on gas.
Old Jun 25, 2007 | 09:36 PM
Exeed's Avatar
Yeah, that about does it. It's because you're low on gas. Fuel pressure's gotta build up enough before the car starts, and when there isn't enough gas, it takes longer.
Old Jun 25, 2007 | 09:45 PM
YAH YAH's Avatar
should i replace my spark plugs and distributor. or am i fine. thanks for all responses.
Old Jun 25, 2007 | 09:46 PM
Exeed's Avatar
If it only does it when you're low on gas, then you're fine. Check, and let us know.
Old Jun 25, 2007 | 09:52 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Next time your low on fuel turn the key on and let it build fuel pressure then turn it over if it starts every time then that will rule out whether its due to low fuel or not. That way you can move onto something else if its not
Old Jun 30, 2007 | 02:13 PM
YAH YAH's Avatar
Default Re: starter? wtf is going on? (ForceFed_Motorsports)
thanks everyone. some more suggestions and advice would help
jmflyd
19
Aug 13, 2009 07:58 AM
jjmajed
May 15, 2007 07:12 PM
alleyezonme
Sep 20, 2006 11:18 AM
spacin
Feb 2, 2005 12:50 PM
T_Rex
Dec 6, 2002 10:41 AM
