Hasport shift linkage, can it work with other mounts?
Old Jun 25, 2007 | 11:56 AM
Raptastik87's Avatar
Default Hasport shift linkage, can it work with other mounts?
Ok, i need a new shift linkage and im looking at the hasport but i read somewhere that it has to be used in conjunction with the hasport mount kit. I know every motor mount company makes their mounts a little different and sits the motor a little different so im thinking this might be why it has to be used as a set. I'm using the place racing mounts and was wondering if that linkage can be used with this, anybody out there use this?
Old Jun 25, 2007 | 12:12 PM
s10cky's Avatar
Default Re: Hasport shift linkage, can it work with other mounts? (Raptastik87)
Yes sir, it will work fine. The located where the shifter bolts too between the two seats is just too bolts, the rubber busing allows the 2 rods to be adjustable.
In other words it will work.
Old Jun 25, 2007 | 04:14 PM
uberhaulin's Avatar
what mounts do u have
Old Jun 25, 2007 | 06:07 PM
Default Re: (uberhaulin)
place racing mounts. I just wanna make sure it'll work before i go and order it cause i was talking to tom at lightning motorsports and he wasn't sure either so he said i should post to find out 100%
Old Jun 25, 2007 | 08:04 PM
gotgsrvtec's Avatar
i have the innovative cable to hydro kit and im using a hassport linkage and it works fine
Old Jun 25, 2007 | 08:06 PM
jdmpnoy89's Avatar
Default Re: Hasport shift linkage, can it work with other mounts? (gotgsrvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotgsrvtec &raquo;</TD></TR><TR><TD CLASS="quote">i have the innovative cable to hydro kit and im using a hassport linkage and it works fine</TD></TR></TABLE>
x2 but i have innovative billet cable mounts w/ a hasport linkage
Old Jun 26, 2007 | 07:17 AM
Wes V's Avatar
Default Re: Hasport shift linkage, can it work with other mounts? (jdmpnoy89)
Rap;
It's impossible for anybody to give you a valid yes/no answer unless they have the same <U>exact</U> set of parts. That's why Tom (at Lightning MotorSports) can't guarantee it will fit.
S10cky's comment is kind of worded wrong, but correct. The linkage assembly "floats" in the bushing that is mounted at the rear (between the seat area) and as a result, the length of the assembly isn't really that critical. What will happen if the modified length isn't "correct" is that the shifter will not be centered within the hole in the floor board. This really isn't a big issue and after everything is put together, you would never know.
On my set-up, the engine placement is similar to the Place Racing mounts and (from my notes) I cut 1.55" from my linkage when I shortened it to fit.
So, you could contact Hasport and ask them how much they shorten theirs and make a judgement call.
Wes
Old Jun 26, 2007 | 09:53 AM
Default Re: Hasport shift linkage, can it work with other mounts? (Wes V)
i know thats why i posted on here to see if anyone had used the same combination(place racing mounts and hasport linkage). But good idea on the call, i'll try and give them a ring, thanks
Old Jun 26, 2007 | 11:09 AM
Got a hold of hasport, they gave me the green light and said it'll work, thanks for all the input guys
Youlose1305
Jul 5, 2006 04:23 PM
B16CRXT
Nov 27, 2004 12:21 PM
civicSIracer96
19
Dec 11, 2003 09:24 AM
Fred n J_v2.0
Aug 27, 2003 05:10 PM
SkyNex721
Sep 28, 2002 08:41 AM
