is it possible to swap wiring harness
i have a 88 dx and im getting a b20b. I wanted to know if i use my ls intake would i be able to use the entire ls harness or would i need to get the jumper harness?
It's always much easier to convert your existing harness to OBD1. If you have the injector harness for the LS, you can use the clips, but I wouldn't recommend using the whole harness. Rywire has some pimp conversion kits. Are you wired for MPFI already?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigluelok »</TD></TR><TR><TD CLASS="quote">no inm not wired for mpfi already thats why i asked if it was possible</TD></TR></TABLE>
Yeah, it's going to be much easier to just convert your existing harness to run MPFI and switch it to OBD1. Like I said, you should use the connectors on the LS harness but not the entire thing. Or just go to http://www.rywire.com, they can put a good conversion harness together for you (for a price of course
Beau Gotti
Feb 12, 2006 02:11 PM
