Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire spec: 91W 87W what's the difference?
Old Jun 25, 2007 | 09:02 AM
yuning83's Avatar
Default Tire spec: 91W 87W what's the difference?
Like the title. If you have 215/45ZR17 91W and 215/45ZR17 87W tires. What's the difference? I know the W rates the speed, but what's the number 91 and 87 doing in front of the speed rating?
Old Jun 25, 2007 | 09:46 AM
zid's Avatar
zid
Default Re: Tire spec: 91W 87W what's the difference? (yuning83)
load index
http://www.tirerack.com/tires/...id=35
Old Jun 25, 2007 | 02:07 PM
yuning83's Avatar
Oh I see, cool thanks man. As always though, I ordered them before I got a answer.
Old Mar 9, 2025 | 04:18 AM
paulivey19's Avatar
Originally Posted by zid
Can you replace the 91w with the 87v
Old Mar 9, 2025 | 07:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The "W" speed rating means that the tire is certified to sustained speeds of 168 mph whereas, the "V" speed rating is only certified to sustained speeds of 149 mph. The load rating is less on the 87V tire, so multiply the load rating weight value of the tire by four to make sure that your maximum loaded vehicle weight isn't greater than this number... and if it is not, then you are good.
lrcrx90
Mar 2, 2007 12:34 PM
B16Civic93
Mar 1, 2005 08:15 AM
RemerLex11
Sep 29, 2004 11:28 PM
Dveloped
Oct 26, 2003 04:27 AM
igo4bmx
Mar 30, 2003 10:39 AM
