alternator will not charge??? WTF???
Old Jun 25, 2007 | 08:37 AM
91_EF_SI_D15b's Avatar
Default alternator will not charge??? WTF???
hey... i have a problem lol... my batt light came on the other day and i noticed that my alt wasnt charging.. so i went and bought a new one and it still wouldnt charge... so then i changed my engine harness and still nothing.. i am clueless at what it could be.. can any one help me??? please and thanks..
Old Jun 25, 2007 | 08:42 AM
CRX Toad's Avatar
Default Re: alternator will not charge??? WTF??? (91_EF_SI_D15b)
I would check cable connections and I would also have new alt tested. I bought a new alt put it in for 2 days and then batt light came on and I had it tested and it was junk. Duracrap built to fail!
Old Jun 25, 2007 | 08:44 AM
Pee Wee's Avatar
Default Re: alternator will not charge??? WTF??? (CRX Toad)
Same thing happened to me. It ended up being the power wire to the fuse box loosened up and began to corrode. Im with toad on this one, check all the wiring
Old Jun 25, 2007 | 09:01 AM
Default Re: alternator will not charge??? WTF??? (Pee Wee)
ok thanks alot guys.. do you think it could be the fuse panel in side the car maybe?
Old Jun 25, 2007 | 09:09 AM
Pee Wee's Avatar
i would check the power wire going to the fuse box in the engine bay
Old Jun 25, 2007 | 07:53 PM
kk
Old Jun 25, 2007 | 09:05 PM
lessonsinspeed's Avatar
Check grounds, and check for corrosion on the battery terminals as well. All can cause problems. Also, check for proper tension of the alternator belt, seems simple, but it can be missed.
Old Jun 25, 2007 | 09:35 PM
cb07's Avatar
You replaced the entire wiring harness? Damn.
Old Jun 25, 2007 | 10:44 PM
Huntley2147's Avatar
i would check the alt because if you got it from napa... they have been producing alot of faulty ones..
Old Jul 3, 2007 | 08:28 PM
Default Re: (cb07)
i didnt change the whole harness i have just changed the front section... the mid section is next tho czu i have done all of the above still nothing
Old Jul 4, 2007 | 09:17 AM
jweeks's Avatar
this might be a stupid question but did you check the battery? A bad battery will kill a brand new alt.
Old Jul 4, 2007 | 11:34 AM
Hawkze_2.3's Avatar
Default Re: alternator will not charge??? WTF??? (jweeks)
Just another suggestion for you, touch a wire from the alternator housing to the head and see if your voltage jumps up. Some alternators have internal grounds and some have to have the housing grounded to the engine (even if they'r both for the same car).
kuplaz
Oct 1, 2018 09:07 PM
aymen_a22
Dec 24, 2013 09:07 PM
DVPDC2
Jul 29, 2008 02:34 PM
samurablaze
Nov 8, 2005 06:31 PM
Proper
Sep 13, 2002 09:29 AM
