HELP!!! Vtec problems!!!
so on my way to work this morning, i noticed that when i hit vtec, it will sputter or seem like its gonna back fire, seems like its at redline already!!! you know when you redline, the rpms drop back a little bit, seems like the motor is gonna blow? it does that when i hit vtec but it only happend like 6 out of 10 times i tried to engage vtec!
(example) im driving in third gear, i slowy get around vtec point (5800), i hit vtec, then the motor jolts pretty hard while my rpms gauge flys back and forth for a quick second from 5900 rpms to 4500rpms! this is when i release the gas as i am affraid its gonna blow! anybody knows what is the cause of this?
you don't slowly get into vtec. vtec requires a certain amount of load to kick in. don't be a girl, mash the throttle down and hold it to red line. you will love it.
yeah, i have a redline at 10,000rpms buddy, i know how it feels
im just saying, my vtec is just hitting inproperly to a point where i can not go past 6000rpm, like its redlining already!
maybe take the vtec sileniod off and check the screen in it and see if its got **** in it.if it does then clean it out. is your timing off???has it been running and hitting vtec fine before??
yeah, i guess i will try taking it off! you think bad oil can be part of the issue? im overdue for one! im actually gonna change the oil today after work so
also, iv had this swap for more then 2 years now, its always hit vtec fine, until now! im trying to load a video on youtube so you can see what my rpms look like when i hit vtec!
when rpm start jumping all over the place in the upper rpm band it's more times than not the igniter. Good thing is you can just go to the local autoparts store and ask for the say 90 si igniter and it’s the same as the one used in the b16 and every other engine and a fraction of the price. I paid $35 for my last one and it’s still going strong that was two years ago. so check the igntier buddy
and just to add on, i have a vafcII and i can see that the vtec does engage! even the sound of the vtec pops but after half a second in vtec, it seems to feel like i just redlined! and its only around 6000rpms!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumbleBee Tuna »</TD></TR><TR><TD CLASS="quote">and just to add on, i have a vafcII and i can see that the vtec does engage! even the sound of the<FONT SIZE="22"> vtec pops </FONT>but after half a second in vtec, it seems to feel like i just redlined! and its only around 6000rpms!
I can see it now.........
</TD></TR></TABLE>I can see it now.........
where is my igniter located in the car??? i dont think i have seen this before, maybe i have but just never paid any attention to it
ok! got the link! check it out! you can see for your self what happens! hope someone can help me out!
http://www.youtube.com/watch?v=kmt4QJXfoq4
It wasn't the igniter on mine it was the cam position sensor inside the dizzy that was going bad. First, I woult check the connections and clean the plugs on the dizzy and see if it helps.
The igniter (a.k.a coil igniter), attaches to... your coil. Basically it's what sparks the whole thing.
A friend of mine had a problem similar to this in his 98 gsr. He was a quart low on oil, so we changed the oil and reset the ecu and it stopped doing it. So... you may try that.
hey everyone, here is an update! on my way to work, it started to do the same around 4000rpms! it happend about 4 times out of the whole 45min drive to work. I didnt get an oil change yesterday so im for sure doing it today, so now i figured it just not the vtec, might be something coming from the ignition maybe? thanks everyone for your help, at least we are getting somewhere, hopefully my motor doesnt blow before i can fix it!
I had the same exact problem. It was the ignitor. It seriously takes 2 minutes to replace. Just open up the dizzy and its mounted inside. Mark where the wires go, or draw a diagram because its not a harness just like four individuals wires with butt connectors.
Oh and make sure to smear a very thin layer or thermal grease on the two mating surfaces. The one i got at autozone was like 40 bucks and it came with a thing of grease.
