That nifty trunk latch you 00/01's got.....
Old Jun 6, 2002 | 11:23 AM
sackdz's Avatar
Default That nifty trunk latch you 00/01's got.....
I was atonished to find that little release lever under the hatch handle. What year was this added (after '97!)? How much does the whole mechanism weigh and does the '97 R have wiring to support it?
Old Jun 6, 2002 | 11:24 AM
Dave-ROR's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (sackdz)
98+ has it. I'd rather have the 97 setup personally.
Old Jun 6, 2002 | 11:25 AM
sackdz's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (01_Yeller_ITR)
Why? Weight? I'm not going to try and do it I'm just curious.
AssPenny's Avatar
I prefer Kings setup
Pull the cord and the trunk pops open
Old Jun 6, 2002 | 11:26 AM
NWPNOMORE's Avatar
Banned
to add it onto a 97-below integra it's a pain in the ***. The whole setup is different. Basically, it's not a simple procedure and IMO not worth doing.
Willard's Avatar
piece o crap...
the thing gets stuck in the open position all the time...
you have to move it over to openand then move it back once the lock is open...
will
[corrected my post]
[Modified by Willard, 10:28 AM 6/7/2002]
Old Jun 6, 2002 | 11:27 AM
Yell00ITR's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (Willard)
I had the latch replaced on my 2000 twice because it would stick and the hatch would not lock closed.
Old Jun 6, 2002 | 11:28 AM
Dave-ROR's Avatar
Becuase I've seen a lot of them stick in the open position (mine does it).. to fix I have to tap the release and then it'll snap back over to locked.. annoying at chit.. also if you have more than one car and your alarm likes your integra's battery power a bit too much it's annoying to use the key to open the hatch, I'd rather just pull a release by the gas door release.. just my opinion
Old Jun 6, 2002 | 11:33 AM
ITR 2K's Avatar
and the truck will not open with the battery unhooked....
will
I agree, I would rather have the older tegs setup. It's a pain in the ***, I remember when I first bought the car, I had no idea on how to open it, then when I figured it out, I had no idea on how to close it. The 94-97's tegs, are nice, simple, and easy to work with.
Old Jun 6, 2002 | 11:38 AM
done's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (ITR 2K)
what little latch?
Old Jun 6, 2002 | 11:43 AM
Super7's Avatar
The pre-98 setup works better. Now, every time I go to open the hatch, I end up opening the fuel door. Habit, I guess.
ITR-01-0977's Avatar
New User
mine sticks open all the time also
Old Jun 6, 2002 | 11:45 AM
PM-Performance's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (ITR-01-0977)
omg im soo happy im not the only one , the 1st time it happened in my 99 teg, i was flipping until i figured what it was. . . .now the one in my R has been doing it alot lately. its really pissing me off. you gotta **** with it for a few mintues to get it to work again .
Old Jun 6, 2002 | 11:49 AM
Austin's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (itr206)
It's an item that I had covered under warranty...the dealership said that they had already seen a couple of other cars come in with the same problem of the latch sticking.
Austin
Old Jun 6, 2002 | 11:55 AM
lanceh's Avatar
25 Year Member
Default Re: That nifty trunk latch you 00/01's got..... (Austin)
man. all j00 f00s got the shaft. neva had any problem with myne.
lance ~ who hopes knocking on this fiberboard desk will count as wood
Old Jun 6, 2002 | 11:59 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I was atonished to find that little release lever under the hatch handle.piece o crap...
will
Hmmm, I've never had a problem with mine. You guys probably use yours more than I do though. I've opened the hatch maybe two dozen times on the car since it was new.
Old Jun 6, 2002 | 12:01 PM
01PYITR's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (lanceh)
The secret for getting the hatch latch to work all the time is drum roll please Spray WD40 in the hole right underneath the latch. (or some other lub spray, I use the Mobile 1 spray for that and it never sticks)
It stuck once when i first got the cat and then used the M1 spray and never again...
Old Jun 6, 2002 | 12:02 PM
done's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (newt2)
wow wow, wheres the hatch leaver? i always use the back
ps: purple valve covers
[Modified by Jordo, 3:02 PM 6/6/2002]
Old Jun 6, 2002 | 12:07 PM
Austin's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (01PYITR)
I had a defective latch...hence the replacement under warranty.
Old Jun 6, 2002 | 12:11 PM
CWITR's Avatar
I have a '98 and have never had a problem. I also have a '94 GSR and like the new latch better.
Old Jun 6, 2002 | 12:13 PM
done's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (CWITR)
where is the latch, any pics of this latch?
Old Jun 6, 2002 | 12:24 PM
Rdriver's Avatar
Default Re: That nifty trunk latch you 00/01's got..... (Jordo)
Mine used to stick all the time on my 01....
Oddly enough I wrecked and crushed in the hatch lid, and the latch was reused on the new lid and I never got a new one.
Old Jun 6, 2002 | 12:25 PM
Racer-X's Avatar
Just goto the trunk and put your hand were you lift up the hatch and there is little black plastic switch there you use to open the trunk.
Hey the hyper rev shows those new alarm keys that look like that laser cut keys of Merc. They can open/lock it, start the engine, cut alarm off and on and it has light so you can see the key holes. If you want the other mags let me know?
Old Jun 6, 2002 | 12:27 PM
Super7's Avatar
You dont have the "latch." It was only on pre-98 Integras right by the fuel door release "latch."
Old Jun 6, 2002 | 12:30 PM
DC2-8888's Avatar
i replaced twice and is like that after a while, this thing so pissed off, wanna break it sometimes, when ppl dunno how to closed when the latched is screw up
