02 Honda Civic Partout, Spoon, Neuspeed, Greddy, ETC.
Well the time has come to finally start parting out the Civic. So I have A LOT of parts for sale.
<FONT SIZE=""5"">*****PLEASE READ****</FONT>
I will be updating this thread constantly as the parts come off my car, and as I find parts lieing around the house, so be sure to check this thread often because I still have a lot of other parts for sale.
Also, for a lot of these parts I am going to need the OEM parts in return. But if need be I can ship out my item first and wait for you to ship out your part back so you have no downtime. BUT that will require that you leave a deposit for the part so I know I get the OEM part back. Also please check my feedback on eBay and 7thgencivic, so you know I am not here to screw anybody and you are buying good parts.
Ok, so where do I start.
The first thing I have for sale is a FULL Intercooler system for a EM2 Civic, with FULL piping, clamps, an intercooler, BOV, and BOV Flange.
This is full custom piping, that runs on both sides. The BOV is a Greddy Type S BOV, and I pressure fitted the intercooler to 20 PSI without any leaks.
The piping was a little dirty when I removed it all, but I cleaned it up a little. A lot of the spots are just stubborn oil and dirt stains that can be removed. The BOV is in perfect condition and I ALWAYS got compliments, because it sounded awesome. High pitched and long. The right side of the piping, has a few dents from hitting the frame, and some scratches on the bottom of the piping, but nothing too bad and it dosen't affect functionality at all. It also has a rust spot where the welding was done, but that can be removed with some CLR I believe.
The price for custom piping alone is expensive, plus a BOV, a BOV glange, the intercooler and everything.
Price = $600 plus shipping
Vacuum Manifold with Hose and Connection
Ok this is for a vacuum manifold and hose with all the fittings already install. Basically a plug and play vacuum manifold. I WILL NOT require any OEM parts in return for this. It hooks up right in the back of the intake manifold.
$60 shipped.
Next is a RevoTeknika short shifter, with CapnYoda's bushings. I will let this go for $50 plus shipping, but I need the factory shifter.
I also have a fake Type R Shift **** and a pre cut AUTHENTIC Type R red stitching shift boot for sale...I can combine all three items for $110 shipped.
This picture has the boot down, but I changed it to move the boot up.
That's a picture of it installed.
I have both door panels done in red suede, which I did myself, so they aren't perfect, but they are damn close. They look good with a few marks and scuffles here and there but it still looks good.
$50 plus your factory door panels. I can also install them if you purchase them and are local.
I have factory Civic SI seats with the red stiching. Pretty good condition, they are clean, just a few scratches on the PLASTIC sides from installation, but nothing that you can really notice. $350 plus your factory seats, again I can also install these, but they are an easy install because I have the brackets bent already.
Factory Red stitching Civic SI Steering wheel, this thing is awesome, I hated that big four spoke factory wheel, and you get to keep the airbag.
Has some regular wear and tear but nothing crazy.
$200 plus your factory steering wheel.
Now for another big part, a FULL return full system.
This is what this will include.
The factory full pump assembly, with a Walboro 255 LPH fuel pump. It comes with enough HIGH quality stainless steel hosing to do the full system (I have the whole hose that runs under the car and fittings) , with ALL the fitings. An Aeromotive FPR with a Jeg's Fuel Pressure gauge installed. Also comes with the fuel rail, with the welded on fitting. The hose that goes from the FPR to the rail and RSX Injectors. Everything you need for a returnless fuel system.
This will also include about another 4 RSX Injectors that are missing O-rings and such, but I won't be doing anything with them.
$500 plus shipping, plus OEM Fuel tank assembly, just what is in your fuel tank. I have not removed the pump and assembly from my tank, but when someone purchases I will remove it.
VIS CF Hood
Used, in OK condition. It has a spidercrack from the inside from my wastegate, which moved to the outside, so the only way to fix it is by painting it, or putting a sticker, or runing some new clearcoat.
Cheap because of the crack $100 plus your factory SSM hood.
Parts I currently have on eBay.
FULL Greddy Ultimate E-Manage with Harnesses and extras
Voodoo Manual Boost Controller
Autometer Pro Comp Boost Gauge
Autometer Pro Comp Volts Gauge
FULL OEM Civic Engine Harness
FULL Greddy Ultimate BLUE With harnesses and support tool
Greddy Black Turbo Timer
SRT-4 577 CC Injectors
Push Button Start Panel with Switches and Ignition
Other parts I will have for sale in the near future...
AEM Uego Wideband Gauge
Wheels
Fiberimages CF Lip
Autometer Gauge Pillar pod
Spoon Sports Lower Tie Bar
KMS Intake Manifold
RSX Rear Sway Bar
And other stuff I can't think of right now.
If you are local I welcome you to come check out the parts in first person, thanks!
$60 shipped.
That's a picture of it installed.I have both door panels done in red suede, which I did myself, so they aren't perfect, but they are damn close. They look good with a few marks and scuffles here and there but it still looks good.
VIS CF Hood
Wheels
Fiberimages CF Lip
KMS Intake Manifold
RSX Rear Sway Bar
PM-Performance
Sep 8, 2003 04:41 AM
