HUGE FS THREAD!! New stuff added all the time. engine parts, itr, suspension
everything must go! make reasonable offers
b series transmission houseing $130
rear t mount $30
rear t mount $30
mounts you pick $15 each
rear mount $15
tranny mounts $20
rear t mount $30
b series axles $50 each
under dash fuse box $10
clutch fork $10
rear mount $30
brake master cylender $20
white steering wheel, for all you "jdm" people $40
power steering fluid bottle $10
black type r door $100
rear t mount $30
water neck with...all that $20
rear t mount $30
under dash fuse box $20
tokico blues with top hat, they blown, if anyone wants them $20 before they go in garbage
alternators....... show me a picture of what plug you need $25
s2000 turbo manifold $150
drilled and slotted rotors front and back, integra size brakes, bad pick but they in good condition just been sitting for a while $80
polished b16 intake manifold $40
b series flywheel with bolts $25
gsr intake manifold $40
rear t mount $30
momo steering wheel with hub, assume eg/dc hub but no guarantee $120
water neck assume gsr? $20
mounts $15 each, fuel pump $40 dizzys $50(see pic)
type r spare tire $30
tranny mounts $20
starter $20
emissions bottle $10
front gsr struts(blown so dont mind them) teg gauge bezel $15 power steering pump $15
trq mount $15
brake master cyl $30
water neck $15
crank pullies $15
b16 throttle bodies $60 each as seen
power steering mount $15
aftermarket fpr $40
fuel rails as seen $15
apc(bigger with black mounts) and forget other brand rear tie bars $50 each
dizzy caps $10
trq mount $15
ITR rear lca's $50(have a single for $20)
Modified by FullRaceAcura at 4:07 AM 6/25/2007
Modified by FullRaceAcura at 12:58 PM 6/25/2007
Modified by FullRaceAcura at 6:40 PM 6/25/2007
Modified by FullRaceAcura at 6:41 PM 6/25/2007
Modified by FullRaceAcura at 11:56 AM 7/18/2007
Modified by FullRaceAcura at 12:53 AM 7/22/2007
Modified by FullRaceAcura at 9:15 PM 8/16/2007
rear t mount $30
rear t mount $30
rear mount $15
tranny mounts $20
rear t mount $30
clutch fork $10
rear mount $30
rear t mount $30
rear t mount $30
rear t mount $30
tranny mounts $20
starter $20
trq mount $15
water neck $15
crank pullies $15
aftermarket fpr $40
dizzy caps $10
trq mount $15
i assume they are from different b series, if you show me a pic of what kind you need i will find it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">Sure got a lot of odd ball stuff.... </TD></TR></TABLE>
word up
god a full set of solid motor mounts for ed/dc theyre stock ones welded solid, $80 bucks
word up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceAcura »</TD></TR><TR><TD CLASS="quote">ok i know you BALLERS in the nw need like a used flywheel, bump</TD></TR></TABLE>
I need one I need one! pm'ed
i know i have a couple but not sure if i have the rubber part of the mount on them, i will check for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabalus206 »</TD></TR><TR><TD CLASS="quote">anything wrong with the tranny? it it a GSR tranny? and wat year?</TD></TR></TABLE>
Its just the case man no gears
haha, it just need to be cleaned, ill try an get a pic sometime of the car it use to be in, like 10 years ago lol
PM'D! HIT ME UP ASAP please! ill come with cash today! right rear lower control arm for 95 integra!!!
monkeyboy313@hotmail.com
Modified by riddlinkid1986 at 10:45 AM 8/20/2007
david
Dec 4, 2008 11:36 PM
Razr2
18
Mar 15, 2008 08:59 PM
fullraceacura
Aug 16, 2007 08:18 PM
lowboost civ
Mar 9, 2003 07:23 PM
