im lookin in to buliding a 89 crx and i dont have a clur of what kind of motor i should put in it i
Old Jun 24, 2007 | 11:23 PM
gotboost10's Avatar
Default im lookin in to buliding a 89 crx and i dont have a clur of what kind of motor i should put in it i
yeah i juss got a 89 crx and i want to hop it up alittle i was told to put a b16 in it but i dont no how much everything would cost does ne one know around how much money it would take to buy the motor ecu trans and that **** ...how fast would a stock b16 make the crx...and if i put a turbo on it could i levave the stock internals in the b26 or would i have to change them?
thanks
Old Jun 24, 2007 | 11:27 PM
bigluelok's Avatar
Default Re: im lookin in to buliding a 89 crx and i dont have a clur of what kind of motor i should put in i
use the search button on the top right corner of the page its the only red button
Old Jun 25, 2007 | 12:07 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboost10 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i juss got a 89 crx and i want to hop it up alittle i was told to put a b16 in it but i dont no how much everything would cost does ne one know around how much money it would take to buy the motor ecu trans and that **** ...how fast would a stock b16 make the crx...and if i put a turbo on it could i levave the stock internals in the b26 or would i have to change them?
thanks</TD></TR></TABLE>if you do the B16 swap yourself, better plan on spending around $2500
from Hmotors - JDM B16A SiR - complete changeover - engine, transmission, ECU, intermediate shaft and axles (which may or may not be any good) = $1499 (add $300 for LSD transmission) plus shipping which is going to run around $250
mount kit and shift linkage $400-$450
going to need header and exhaust work
before you install it, you should replace the timing belt, front and rear seals and oil pan gasket - hoses, oil, oil filter, spark plugs, coolant, etc. ($ adds up)
if your CRX is HF, you will need to replace the knuckles/hubs
if you want to boost it and want it to last, you will need to build-up the bottom end
Hatch_Boy
May 21, 2009 07:08 PM
Mike04Civic
Apr 11, 2006 09:47 PM
jso89
Jan 15, 2005 11:45 AM
NateDawgCRX
15
Nov 6, 2002 03:23 AM
