Oil pump DOHC ZC
Old Jun 24, 2007 | 10:49 PM
ZCMeGone's Avatar
Default Oil pump DOHC ZC
gotta weird noise coming from the alternater area, hoping its not the oil pump, but i think it is, what do you have to do, step by step to get it out and replace it??
and what kinda oil pump do i order for an DOHC ZC motor???
is it a stock CRX Si pump or what??
Old Jun 24, 2007 | 11:43 PM
jlicrx's Avatar
Default Re: Oil pump DOHC ZC (ZCMeGone)
i would suspect bad bearing before the oil pump - in either case, you should check the bearings
p.s. don't believe those claims of only 25,000 miles on these engines
Old Jun 25, 2007 | 03:21 AM
abnaasefmb's Avatar
Dude, why not just stick with one string and ask your questions from there? Also you can use the search feature; lots of people successfully use it every day. Thanks.
Old Jun 25, 2007 | 07:35 AM
cr-x-91's Avatar
18 threads.......when will it stop. like he said ^ this all could of been discussed in one thread.
Old Jun 25, 2007 | 08:03 AM
CRX Toad's Avatar
This all needs to be in one thread. DO NOT create this many threads at one time again.
Dumped89Si
May 27, 2015 07:32 AM
SloCivicHMM
Aug 7, 2003 11:40 AM
levears
Jul 15, 2002 05:15 AM
Phatman91624
Apr 25, 2002 07:46 PM
