92 accord problems
Old Jun 24, 2007 | 10:17 PM
jonathanraycamacho's Avatar
Default 92 accord problems
can somebody help me out.
my car when i first start it up, idles at 1500. but when the engine gets hot it idles where it should. why does it do that.?
and does anybody know that mpg on 92 accords (4dr)???
thank you.
Old Jun 25, 2007 | 03:24 PM
Jstall7543's Avatar
Default Re: 92 accord problems (jonathanraycamacho)
If your engine is cold it will do that till it warms up, its sorta like a choke on a carb!
My 90 Ex 2dr 5 speed gets around 28+ @70 mph
Old Jun 25, 2007 | 04:33 PM
JDM_DC4_Fanatic's Avatar
Default Re: 92 accord problems (Jstall7543)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstall7543 &raquo;</TD></TR><TR><TD CLASS="quote">
My 90 Ex 2dr 5 speed gets around 28+ @70 mph </TD></TR></TABLE>
28+ what?
To the OP. There is a Fast Idle Thermal Valve that makes the engine idle high for a few mins to get the temperature up, and the engine warmed up properly. This is to make sure that all the systems are working properly. For example, build oil pressure, and get it circulating. Build some heat in the exhaust to get the o2 sensors working, etc..
So, to answer your question, its perfectly normal for your car to idle at around 1500 rpm when first started COLD for a few mins. If the engine still idles high after it has temp, then thats another problem.
Old Jun 25, 2007 | 05:15 PM
minnie's Avatar
Honda accord parts like its engine is advisable to warm up before running.
foxboysracing
Nov 20, 2015 08:33 PM
stevescivic
Jan 12, 2007 08:51 PM
wontstart
Sep 7, 2005 06:26 AM
chrispaul
Mar 19, 2004 06:38 AM
BAZ
May 4, 2003 03:41 PM
