just woundering has anyone tried to fit the 05+ odessey calipers?
i have a broken type r knuckle at work that i keep around so whenever i do brake jobs i see what random honda rotors would fit lol.
anyways...doing a brake job on an 06 odessey saterday i took my spare knuckle out and notice the caliper bracket lines up. but the only problem is the bolts are bigger they are 19mm vs the standard 17mm.
i also notice the rotor had the same inner bore as the type r rotor. but the lug pattern on the odessey is alot bigger.
i do remember the thread while back about retrofitting the tl brembo calipers. on to the type r.
just woundering..if is it possible to bolt the odessey caliper on to the type r caliper bracket has anyone tried this yet?
i would try but i dont have a spare caliper bracket laying around.
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
